Intellijel Triplatt?
Author Intellijel Triplatt?
acmesound
Saw a listing for a 'triplatt' on Moogaudio's site today but didn't find it on the Intellijel site… is this a new version of the Triatt? A replacement?
https://www.moogaudio.com/en/all/new-product/intellijel-triplatt-3u
zanscath
I've noticed some stores don't have triatt in stock anymore so this might make a lot of sense.
bedhed3000
There's also a few new 1U modules on that site. Looks like none of this stuff is actually in stock though. I'd be surprised if these start shipping any time soon.
Dragonaut
edit: the link explains the functions
toxoplasma_gondii
Triplatt is a three-channel active/buffered attenuverter and summing mixer.
Each channel has a knob, which can function as a unipolar attenuator or a bipolar attenuverter, depending on the setting of its corresponding two-position polarity switch.
Each input is normalled to a built-in precision +5V DC voltage source.
With nothing plugged into the jacks, each knob controls a voltage range of 0 to +5 V or -5 to +5 V depending on
the position of the channel polarity switch. Outputs A and B are also capable of a range of 0-10 / -10 to +10 when using the special function switches.
Each output is normalled to mix into the output of the channel below, making it possible to do sub mixes in groups of two or three.
In addition, each channel has a “special function” switch to alter its input voltage in a specific way.
Channel A has a 2x voltage multiplier switch, allowing you to double the voltage sent into Channel A.
Channel B has a +5V switch, allowing you to add 5V to whatever voltage is sent into Channel B.
Channel C has a mute switch, allowing you to completely turn off the signal being sent into Channel C.
cg_funk
Wow this looks pretty handy! applause
cackland
Wonder if they implement the changes into the Quadratt in the future?
rbhansen
I read somewhere (Muffs?) that the Triatt was going to be discontinued and replaced by something else. (Sorry--can't for the life of me find where I read that. I know, I know...not very good "proof").
Kind of forgot about it for awhile but then just saw this post and suspect folks are correct--this is the replacement.
The moogaudio link is down, but Thomann has it up on their website (https://www.thomann.de/gb/intellijel_designs_triplatt.htm).
My guess is that we're getting close to release date.
Triglav
from: https://www.muffwiggler.com/forum/viewtopic.php?t=216976
