PitchMaster - Hinton Instruments
Author PitchMaster - Hinton Instruments
monads
Anyone using one w/examples??? This module gots me curious in a system with different/multiple oscillators and helping to tune. But wondering how others are using or other applications.
flo
I have one, it's fantastic! No audio examples (yet), though. I mostly use it to control several VCOs, but it can also come in handy if you need an offset for something other than pitch CV. Of course, it could also just work as a set of precision summers if you keep the switches at zero. The Master Tune is very useful to fine tune several VCOs once you have a patch going. The implementation of the semitone functionality is also very clever. All in all, lots of options to create complex CV signals. Even better when combined with a Hinton matrix hihi
Now, I "only" need to perfectly calibrate my VCOs to it Dead Banana
Cheers Guinness ftw!
Llouwelyn
I use PitchMaster all the time since it was released.
In my system all VCOs are be calibrated with Pitchmaster. There is performance controls for 2 or 3 VCOs like a Minimoog, plus precise semitone steps are available too.
Knob Sum 2.5 +/- semitones is very useful when you working a sound and you let go of your imagination, this fonction is pratical for adjusted with précision alls VCO...
I have a few demos sound but I don't know if it this can be help!
Of course you can use Pitchmaster with your VCF's. oops
Every system should have one! thumbs up
monads
Thanks for the feedback!!! I typically calibrate individual VCOs patched to a sequencer and recall a default 'tuning' sequence from storage memory. I can see offsets coming in handy and the Mater Tune. I should probably just patch my VCOs to the PinMix as a starting point and add Pitchmaster to the foray.
