218e pairs with 225e for MIDI as in Easel Case?
Author 218e pairs with 225e for MIDI as in Easel Case?
@green
Anyone know if the 218e if in the same case as a 225e will sync to midi beat clock and send on the 4 midi busses as it does when seated in an easel case?
Drillionaire
Only if you have a MIDI breakout for the 218e and are sending it MIDI from something. The MIDI 225e and 218e both put MIDI data onto the bus but do not communicate with each other (other than the preset manager portion of the 225e displaying the 218e firmware version when instructed to).
@green
Oh yes of course with the midi breakout. So it would allow the arpeggiator to sync to beat clock with it coming in the midi in of the breakout? So the clock would come into the 218e through the EDAC?
Drillionaire
Sorry, I should have clarified, a MIDI breakout for the 218, not the MIDI breakout for the 225e.
@green
Gotcha, thanks!
Also found this after some poking
https://buchla.com/guides/Buchla_MIDI_I-O_panel_advanced_use_guide.pdf
