Intellijel Triplatt
Author Intellijel Triplatt
intellijel
Triplatt is a three-channel active/buffered attenuverter and summing mixer. Each channel has a knob, which can function as a unipolar attenuator or a bipolar attenuverter, depending on the setting of its corresponding two-position polarity switch. It’s a versatile and super handy utility module that will find its way into almost any patch you make!
Each input is normalled to a built-in +5V DC voltage source. With nothing plugged into the jacks, each knob controls a voltage range of 0 to +5 V or -5 to +5 V depending on the position of the channel polarity switch.
Each output is normalled to mix into the output of the channel below, making it possible to do sub mixes in groups of two or three.
In addition, each channel has a “special function” switch to alter its input voltage in a specific way. Channel A has a 2x voltage multiplier switch, allowing you to double the voltage sent into Channel A. Channel B has a +5V switch, allowing you to add 5V to whatever voltage is sent into Channel B. Channel C has a mute switch, allowing you to completely turn off the signal being sent into Channel C.
https://intellijel.com/shop/eurorack/triplatt/
MANUAL
Modular Grid
Width 6HP
Depth 21mm skiff/palette friendly
Power 49mA @ +12V 25mA @ -12V
MSRP $109 USD
Available now!
Phitar
So this is replacing the Triatt?
cackland
One would assume so
monads
Looks ace!!! Wondering if I should switch out my Fonitronik Cascade but those are 4hp. The Triplatt has more features so kinda a compromise features to hp dilemma.
pieter
Does it clip audio in a pleasing way?
