Having trouble setting up RME + ES-3 (only outputs 1/2 work)
Author Having trouble setting up RME + ES-3 (only outputs 1/2 work)
pvdn
I am trying to get the Silent Way plugin to work with my RME FF-UC, but for some reason i only seem to be able to send something to outputs 1 and 2.
I am guessing that this is not related to SW (not sure) since i do see the channel-meters in Ableton respond - i just dont seem to get any signal for channels other than 1/2 in my RME Totalmix (and obviously also not in my ES3).
Is there a setting i am overlooking?
DJMaytag
Check your RME device specific settings for the optical output options. I have a RME Digiface USB, and there’s a drop down for all 4 outputs. Each output can be configured for either ADAT or standard SPDIF. If the optical output is set to ADAT, then check your routing in TotalMix.
