Request - FH-2 - Add MIDI Thru to MIDI DIN Out
Moderators: Kent, os
danpisarcik
Post by danpisarcik » Tue Jul 16, 2019 2:33 am
I'm wondering if it would be useful to others to have USB->DIN MIDI Thru on the FH-2.
This could also enable direct connection between Disting & FH-2 via the breakout pins, allowing activity at the FH-2 MIDI input to be forwarded to the Disting.
One could then map some portion of a USB controller to some controls to the FH-2, whiie forwarding to handle the remainder via DIN breakout.
Could this be possible in a future firmware? Taken one step further, a control panel could provide options to disable/enable any combination of the 16 MIDI channels forwarded to the DIN output for added utility.
Cheers.
Post by os » Tue Jul 16, 2019 2:35 am
Yes, it's possible. Thanks for the suggestion.
kpreid
Post by kpreid » Tue Jul 16, 2019 11:42 am
Related: how about supporting DIN IN to DIN OUT forwarding, so with the DIN expander one can effectively have a traditional DIN IN and THRU port?
Post by os » Tue Jul 16, 2019 11:48 am
You know, that's exactly what I thought danpisarcik was asking for.
Now I see he's asking for what's already there - USB->DIN forwarding is already implemented.
danpisarcik
Post by danpisarcik » Wed Jul 17, 2019 10:55 pm
Apologies, I failed to use good search terms the first go around. MIDI forwarding is now working well. Thanks much.
Hope the DIN -> DIN idea that came about is also useful, as some small consolation.
Triscus
Post by Triscus » Thu Oct 03, 2019 3:17 pm
+1 for DIN Forwarding 8-)
Post by os » Fri Oct 04, 2019 2:31 am
This was added in 1.7.2.
Triscus
Post by Triscus » Fri Oct 04, 2019 4:22 am
Oh,I missed it. I didn't had a look at the firmware page, just checked the announcement on the homepage.
Thank you very much. My MIDI breakout arrived yesterday and already missed the forwarding.
Return to “Expert Sleepers”
