[ORDER] Triple Function Generator project
Moderators: luketeaford, Joe., lisa, Kent, daverj
FetidEye
demonic space drone
Post by FetidEye » Fri Jul 19, 2019 12:02 pm
The Triple Function Generator Project
This module is based on schematics by D.Sandin & L.Larsen
I picked up this project because the pcb’s are not available anymore.
The Function Generator is a very useful module to have in a (DIY) video setup.
You can adjust the “Lights” , “Mids” and “Darks” in the input signal.
Effectively it works a bit like an equalizer, but you can also go negative. This will get you solarised effects.
I setup the design to work as a triple colorizer, as the Cadet system has black & white video input.
With this module, you can easily recolor the incoming images.
The inputs can be normalled together to achieve this. (there are connection pads on the pcb’s)
Feedbacking this and through module will also give cool results! — hint: more on this later
pcb & panel images:
more info:
https://community.lzxindustries.net/t/o ... -generator
https://www.reverselandfill.org/diy/tri ... r-project/
Prices: (ex shipping) - note: I've ordered more pcb's. the initial 7 sets are spoken for.
Full PCB SET (3x PCB + Panel) : 48,- euro
Single PCB (1x PCB): 12,- euro
Full kit: 110,- euro
Build unit: I might do one. PM me
Flat rate shipping is 9,- euro for EU and international, 6,- euro for NL
Please reply with what you want to order.
(not on both forums please; I'll add you there for clarity)
I’ll make a list.
orders:
1: TomTones - 3x pcb's , no panel
2: pathein - Full PCB set
TomTones
Post by TomTones » Sat Jul 20, 2019 5:50 am
I would like 3x PCB thanks
pathein
Post by pathein » Thu Jul 25, 2019 7:38 am
will like to get 1x full pcb set, thanks
FetidEye
demonic space drone
Post by FetidEye » Tue Aug 06, 2019 11:45 am
The new panels are almost here.
When all is ready, I'll contact you all!
fluxmonkey
Post by fluxmonkey » Tue Aug 06, 2019 12:51 pm
i thought I had replied previously? but if not, I'm in for a full set. thx!
www.fluxmonkey.com
BUILDER FOR HIRE - kits or custom, email me with your needs
FetidEye
demonic space drone
Post by FetidEye » Tue Aug 06, 2019 4:25 pm
you replied on the LZX forum :)
FetidEye
demonic space drone
Post by FetidEye » Sat Aug 17, 2019 3:09 am
payment messages are send!
Return to “Video Synthesis”
