issue with FH-2 MIDI/CV converter Y-axis response
Moderators: Kent, os
saiteron
Post by saiteron » Sat Jul 20, 2019 6:03 pm
i sat down with the FH-2 and my Linnstrument to build a new configuration today and discovered a strange bug: only the first MIDI/CV converter will actually convert Y-axis data to output.
i discovered this as i was building a configuration that uses the "split" function on the Linnstrument to divide the playing surface into two separate instruments. i set both to be identical in configuration except for the MIDI channels they used so i could have one half as a monophonic bass voice and the other half as a duophonic lead/chord voice. for the FH-2, i ensured settings were identical for the first two MIDI/CV converters except for the MIDI channels they were set to receive. after pushing the configuration to the FH-2, only the first MIDI/CV converter output anything in response to the Y-axis CC 74 even though the screen showed both "splits" on the Linnstrument were sending CC 74 data. i even set up an alternate preset on the Linnstrument with the splits' settings swapped and still only the one sending to the first MIDI/CV converter on the FH-2 outputs any Y-axis information.
Post by os » Wed Aug 28, 2019 4:23 am
Confirmed. I'll get that fixed for the next update.
Return to “Expert Sleepers”
