[Build] Dannysound - Timbre Wavefolder
Monobass
thonk.co.uk
Post by Monobass » Wed Jul 24, 2019 3:20 am
The Timbre is 6HP Eurorack module based on the wavefolder section of the Buchla 259 oscillator as implemented in the Music Easel.
The wavefolder adds extra harmonics to input signals that have low harmonic content to creating rich and interesting timbres.
Typical input sources to use would be Sine and Triangle waves but you are welcome to try other sources as well!
The Dannysound Timbre adds an extra input to the Buchla design to allow 2 oscillators to drive the wavefolder simultaneously
– this dramatically increases the range of possible tones that can be generated and allows the folder to go wild!
Read more and buy the kit – Here
Build Document – Here
Schematic – Here
Features
  • Osc1 / Osc2 Mix – Adjusts mix between oscillator 1 and 2 inputs, also acts as an attenuator if only one of the inputs is used.
    Timbre Control – Adjusts the overall wavefold amount.
    Timbre CV – Bipolar (attenuverter) controls the Timbre CV input.
    Symmetry – Adds an offset to the input so the top half of the wave starts folding earlier.
    Blend – Mixes between the clean and effected sound.
Ins / Outs
  • Osc 1 Input
    Osc 2 Input
    Timbre CV Input
    Symmetry CV Input
    Blend CV Input
    Audio Output
Thonk - CLICK HERE - Modular Synth DIY + Eurorack Accessories Store
intercorni
Post by intercorni » Fri Sep 06, 2019 7:03 am
Hello,
is it possible to build the wavefolder with +/-15V?
dannysound
Post by dannysound » Fri Sep 06, 2019 7:29 am
intercorni
Yes it should be ok, you definitely won’t break anything. You might need to play around with a few resistor values but I haven’t tried it so I can’t say for sure.
Give it a go and if you run into any problems let me know.
intercorni
Post by intercorni » Fri Sep 06, 2019 8:20 am
Many thanks!
jamos
Post by jamos » Sun Sep 08, 2019 7:18 pm
I built this today, it is a really straightforward and elegant build. The instructions are detailed, almost too detailed when you consider all the pictures of resistor placements. I found that I could place the resistors easily just from the parts list, as everything is beautifully labeled on the boards. This is a 3 board module, with lots of headers between the boards. I did not do either of the mods listed on the last page, but I suspect the two resistor changes to increase the range of modulation and symmetry might be helpful.
Nord Modular G2 & G2X, Emulator X, MPC Live, and a growing Euro system.
Schanke
PCB + Panel kit also available anywhere?
Post by Schanke » Tue Oct 29, 2019 8:24 am
hi there, anyone knows if its possible to buy a only Pcb panel kit somewhere?
Agawell
Re: PCB + Panel kit also available anywhere?
Post by Agawell » Tue Oct 29, 2019 12:12 pm
Schanke wrote:hi there, anyone knows if its possible to buy a only Pcb panel kit somewhere?
thonk, eventually!
based on the other DannySound modules - they were available as kits for a while and then pcb/panels arrived
my guess is sometime next year...
Instagram
Utility modules are the inexpensive, dull polish that makes the expensive, shiny modules actually shine - and stops them tarnishing too!!!
Schanke
Post by Schanke » Tue Oct 29, 2019 2:56 pm
thanks @agawell.
thonk only has the kit. i will write them and ask if they will sell me only the pcbs and the panel.
cheers.
Footkerchief
Post by Footkerchief » Tue Dec 17, 2019 2:14 pm
Is the Symmetry knob always an offset, or is it an attenuator for the CV input with a normaled DC offset?
brandonlogic
Re: [Build] Dannysound - Timbre Wavefolder
Post by brandonlogic » Tue Apr 14, 2020 1:46 pm
looking to purchase one of these built new or used. please let me know if anyone has any leads
