USB Din dongle causing locked notes.
Author USB Din dongle causing locked notes.
Shor
Os,
I emailed you before about this issue I had with my Octatrack sequencing that caused some midi notes to hang, as no velocity 0 was sent.
Turns out this was entirely caused by my usb-din dongle, as I guess it's just not fast enough sometimes.
I tried this again using my Digitakt as a USB-converter of sorts (OT sequencing DT midi tracks) and with that I can't reproduce any stuck notes.
Just posting this here in case anyone else runs into the same issue if they are using cheapo usb-din adapters into FH-2.
Will get a Retrokits RK-005 to convert my midi from now on. Will probably grab a DIN expander for FH-2 at some point though when something comes in stock.
