New Teensy 4.0 - phenomenal performance vs cost
Author New Teensy 4.0 - phenomenal performance vs cost
TuskSE
Look at this madness!
https://www.pjrc.com/store/teensy40.html
ARM cortex-M7 running at 600Hz
Hardware float and double calculations
I2S and S/PDIF digital audio
Teensy 3.2 pin compatibility
$20 (!)
Only downside is the 100mA power draw.
That aside: as far as I understand, this is much more power than anything used in mutable instruments lineup. Just gotta figure out what I actually need all that power for...
I feel the potential for an Ornament & Crime type thing with digital oscillators, filters, etc.
Also, If I understand the chip data sheet right, the PWM outputs are clocked at 150MHz - I haven’t done the sums, but maybe this is sufficient for high resolution and fast CV output without the need fro an external DAC?[/s]
jorg
I have been developing some FX algorithms that could benefit from a fast FPU. This looks pretty interesting.
Teensy 4.0's CPU is claimed to be very friendly to both overclocking, and clock speed changes, without disrupting peripherals. That is aimed at letting you manage power by adjusting clock speed. You might even dial it up or down to match the amount of code in your algorithm.
guest
yeah, that thing is crazy. and 100mA seems low to me for that much power. its probably better than the computer im using right now.
jorg
If you power it with an on-module switcher, you might expect to draw about 36mA from the +12V rail. Not much at all!
fuzzbass
OK but this does not mean we get another twelve functions for o_C. The manual is already 60 pages long! Rockin' Banana!
toneburst
It's not 100% pin-compatible with Teensy 3.x, so it probably won't work as a drop-in replacement, anyway.
pld
The faster core can run a deep learning model that infers predictive parameter sets, so the module interface gets more streamlined and intuitive as ever more apps are added, rendering manuals obsolete. Tada!
Sandrine
I like the i2s has SAI capability, codecs are nice on SAI. This is a really interesting powerful dev board for audio I/O. I wonder how the Arduino IDE support is for that?
Timmy
The T4 pins are compatible-enough to potentially allow it to be a drop-in replacement for the T3.1/3.2 in the original 14HP O&C design. However, it's not that simple, and there are a myriad of tricky timing issues etc that mean a LOT of changes, many of them involving a lot of trial-and-error, and hence time, would be required to get a T4-enabled O&C to work. That's not speculation: mxmxmx has had access to a pre-beta and then a beta T4 for several months, and started to investigate the retrofitting issues. He got as far as eventually getting the beta T4 to boot, but only after disabling probably about half the code (and the display etc). But the real showstopper is that it now appears that the onboard ADCs, on which O&C modules rely, are actually a lot less precise in the T4 than they are in the T3.2, rendering it useless for quantisation duties. Thus, a T4 upgrade to existing O&Cs is unlikely to be feasible, and almost certainly not effort-effective. Plus, it the T4 won't physically work with the microO&C variants, that use connections to pads underneath the T3.2. Those pads are completely different in the T4, so an adaptor board would be required. Just doesn't seem like it is worth the effort, given the architectural limitations inherent in the O&C design anyway. Can't make a silk purse out of a sow's ear.
Timmy
We've been talking to Elon about his NeuraLink] thing... https://neuralink.com
mxmxmx
Timmy wrote:
toneburst wrote:
fuzzbass wrote:
OK but this does not mean we get another twelve functions for o_C. The manual is already 60 pages long! :bananaguitar:
fwiw, it's entirely pin-compatible (in terms of O&C) so that's not really the issue; all the needed signals are there (and plenty more); just the 1062 ADC might be a little less suitable, i don't know. also, it does/should boot up (there were issues with the PMIC / power-up sequencing in the early phase of beta testing, ie when powering the thing from 12V / some DC|DC converter, but that's been resolved. at least it worked here, eventually)
so porting the code should be entirely doable. chances are the pay-off is going to be very slim though, as was pointed out, mainly because of existing bottlenecks (the OLED/DAC shared SPI bus). with the 1062, there's a few more options to disentangle the DAC/OLED now, but then we're already talking about new/different hardware; i've already cooked up something IoTesque, but progress (re firmware) has been very slow (due to lack of time/motivation/skills).
MapacheRaper
Ohh, that´s a pity. I was drooling with the idea of my o_C v4.0 Dead Banana
But thanks for the clarification!
joem
It'll be interesting to see what new modules take advantage of the Teensy 4, and how they take advantage.
I want to get my hands on one to see what it can do video-wise. Really curious if the PXP can be used in some useful way with composite video signal generation. Trying to parse the datasheet but pixel pipeline might be a bit beyond me right now.
Roni
Teensyduino is an add-on for the Arduino IDE and brings full support for all Teensy revisions. It works quite well.
cackland
Curiosity has me too.
Dogma
So does that mean an update to the rll sandy? That would be amazing
kallikak
That's an amazingly powerful little device. I just wish they'd make it just a tiny bit bigger so all pins were breadboard friendly and avoid the surface mount pads underneath.
Ken
