TR-707 Only plays BassDrum over midi
talkboxert
Post by talkboxert » Fri Aug 09, 2019 4:09 pm
Hi there, just dusted off my 707, was looking forward to jam with my laid trigger to midi module, but...... (jaws music)
It only plays the bass drum when I send it midi notes (both bass drums work) Yes I plugged it in to the main stereo out :)) That means midi works, also midi sync does, but the other sounds keep their mouths shut :sadbanana:
Anyone else ever run into this problem? Or have an idea what could cause this?
GrantB
Post by GrantB » Sat Aug 10, 2019 1:05 am
Did you do the MIDI note assign as detailed in the manual? You probably need to set up which note # triggers which voice.
talkboxert
Post by talkboxert » Sun Aug 11, 2019 6:18 am
Hah! thought this was all just fixed :doh:
worked like a charm, thanks
GrantB wrote:Did you do the MIDI note assign as detailed in the manual? You probably need to set up which note # triggers which voice.
