Mutable Frames
ronaldroy
Mutable Frames
Post by ronaldroy » Sat Aug 10, 2019 6:38 pm
I've just bought a Frames module (DIY) that isn't working properly and wondered if there's anything simple I can check on it to troubleshoot (already tried the reset/calibration procedure). The individual channels work OK but things are a bit screwy with the combined inputs/outputs and offest mode - some signals aren't present at mix and vice versa.
Any thoughts?
Agawell
Post by Agawell » Sat Aug 10, 2019 7:22 pm
send it back to where you got it from for them to fix
ronaldroy
Post by ronaldroy » Sat Aug 10, 2019 7:25 pm
Agawell wrote:send it back to where you got it from for them to fix
Brilliant, hadn't thought of that.
Dcramer
Post by Dcramer » Sat Aug 10, 2019 7:38 pm
Do you know if it has the original Frames OS, or Parasites installed?
Zymos
Post by Zymos » Sat Aug 10, 2019 8:20 pm
It's actually a pretty good suggestion. I bought a DIY one (Plancks II) myself, and it had problems from the moment I plugged it in. I sent it back, got a refund, and bought another from a better builder.
ronaldroy
Post by ronaldroy » Mon Aug 12, 2019 7:03 pm
Dcramer wrote:Do you know if it has the original Frames OS, or Parasites installed?
Good question. I'll check when I'm next in front of it. um ... how would I do that again? :) :hmm:
wiggies
Post by wiggies » Mon Aug 12, 2019 10:51 pm
Easy check is for LFO mode in Parasites. Press and hold both buttons to engage mode selection, then turn the 3rd knob to engage LFO. Press one of the buttons again.
If you're in Parasites, you'll have 4 LFOs going and the lights under each knob will pulse. The big knob controls frequency and changes color from red (lowest) to violet (highest).
If you're not in Parasites ... it won't do that.
