l1 stereo mixer - experiences building?
Author l1 stereo mixer - experiences building?
lilnoah95
I've read great things about this mixer, has anyone built one? Would it be an ok second DIY module, or is it super complicated and difficult?
yaongi~
This one?
I think the build is straightforward if you're methodical.
I did mess something up, as usual.
First, make sure you get the Farnell leds, ones I got were from a mouser cart for one of the other L-1 modules and were way too bright no matter what resistor I used, so I recommend getting the Farnell ones in the bom, as I did in the end anyway.
Also a couple of electrolytic caps are small size. So watch out when substituting.
If you have the right parts the build is not difficult, I think.
I have four of these modules now, as an in rack mixer.
lilnoah95
hey yaongi! thanks for the reply, i didn't realize that they had so many different mixer builds available. i should have specified that i was looking at the vc stereo mixer razz Thanks for the advice though, im sure it applies to the more complicated ones as well!
yaongi~
That's cool. I've built a number of L-1 modules now, including some more complicated builds, and none have been difficult when I had the right parts. Though I did get them with smd components installed.
Probably the LED advice holds for the mixer you're looking at.
FrogStar
This is great module and a very easy build for what you get.
All L-1 modules are great, but this one and and the Dual Analog ADSR are absolutely tops.
TheMentat
I haven't build the module in question, but have build a few of his other ones. Very high quality PCBs and all were straightforward builds.
lilnoah95
ok great to know, thanks for the responses yall -- do you think it would be an ok first build?
