Issue with AJH Synth Minimod VCOs' pitch stability
themonthfollowingmay
Post by themonthfollowingmay » Mon Aug 12, 2019 9:09 am
I currently own two AJH Synth Minimod VCOs. I have noticed that they are not very stable and especially one of them keeps fluctuating, which makes it really difficult to use. AJH Synth has a great customer service and they have replaced them for me in the past but I keep having issues with them. I have three cases all with Doepfer PSUs and the VCOS behave in the same manner in all three of them. I have noticed that other people who own Minimod VCOs do not face such issues, I have no idea about what could be causing this. By the way, I have 2 Make Noise STOs, which I have used in the same cases but I never had a problem with them.
Any assistance would be kindly appreciated.
BaloErets
Post by BaloErets » Mon Aug 12, 2019 9:25 am
Hope some of us are able to help. Would you mind elaborating on what you mean by "stability"? Are you having issues regarding tracking when shifting octaves, or is it more related to fluctuations in pitch?
Post by themonthfollowingmay » Mon Aug 12, 2019 9:36 am
thanks for your reply.
BaloErets wrote:Would you mind elaborating on what you mean by "stability"? Are you having issues regarding tracking when shifting octaves, or is it more related to fluctuations in pitch?
I am having issues with fluctuations in pitch. Especially on one of them, the pitch is constantly fluctuating and at times it will get suddenly out of tune by almost a semitone. This behaviour is happening also when I have nothing plugged in the 1V/Octave, Exponential & Linear FM inputs.
mdoudoroff
Post by mdoudoroff » Mon Aug 12, 2019 10:05 am
Have you tried contacting Allan? info@ajhsynth.com
Post by themonthfollowingmay » Mon Aug 12, 2019 10:07 am
mdoudoroff wrote:Have you tried contacting Allan? info@ajhsynth.com
Yes and he has replaced my AJHSynth VCOs in the past for the same reason. I wanted to post here first this time to ask other users before I contact him again.
mdoudoroff
Post by mdoudoroff » Mon Aug 12, 2019 10:54 am
Well, I only have one AJH VCO and it’s rock steady. #anecdoteIsNotData
Post by themonthfollowingmay » Mon Aug 12, 2019 11:27 am
I have five of their modules and they are all great.
However, the issue that I described above makes it really difficult to use the VCO.
mdoudoroff
Post by mdoudoroff » Mon Aug 12, 2019 12:05 pm
I think you need to talk to Allan. Maybe he has ideas?
indexofmetals
Post by indexofmetals » Mon Aug 12, 2019 12:16 pm
it's probably worth asking Allan if this has happened to any other users, if it's also happened to ones he replaced of yours before.
I've got 8 of his vco's, and have used them with at least 5 different power supplies and never had any kind of issue. There's the most solid vco I've got tuning wise.
Keltie
Post by Keltie » Mon Aug 12, 2019 12:30 pm
Quick questions. Are they in the same case together? Is the problem apparent when you patch something in from a different case ( say, a sequencer). Are your +12 and -12 loads very dissimilar in one ( or more ) of your cases?
I’ve had some odd pitchyness when patching between cases, with lots of digital in my rig, so not equal draw on +ve and -ve.
I’m no expert but if you look at power/ common rail / zero volt threads, you’ll see Graham Hinton and others discussing this issue at length.
Post by themonthfollowingmay » Mon Aug 12, 2019 12:59 pm
indexofmetals wrote:it's probably worth asking Allan if this has happened to any other users, if it's also happened to ones he replaced of yours before.
Yes, I am going to ask him. I have read that others had similar issues with me but I have also read others, like you, saying that the AJH VCOs are extremely steady. The strangest part is that I have other oscillators in my case that are extremely stable.
Keltie wrote:Quick questions. Are they in the same case together? Is the problem apparent when you patch something in from a different case ( say, a sequencer). Are your +12 and -12 loads very dissimilar in one ( or more ) of your cases?
The problem is always apparent, I have even put just the two VCOs alone in a case and it is still the same.
indexofmetals
Post by indexofmetals » Mon Aug 12, 2019 1:26 pm
how long ago did Allan replace the vco's? Have they been unstable the entire time since they were replaced?
Post by themonthfollowingmay » Mon Aug 12, 2019 1:38 pm
indexofmetals wrote:how long ago did Allan replace the vco's? Have they been unstable the entire time since they were replaced?
He didn‘t replace both of them at the same time as only one of them was problematic at the time. It started acting strange again after almost a year.
abku
Re: Issue with AJH Synth Minimod VCOs' pitch stability
Post by abku » Fri Jan 10, 2020 9:59 am
HI I noticed issues with mine, in depends wich places, I gees because irregular electricity feeding the modular, makes the filter buzz and osc acting in strange behabior like tuning fluctuation, try connect in friends or family house to see if the problem persist.
