comparator? thru zero detection? increasing decrasing? Euro?
lacuna
Post by lacuna » Fri Aug 16, 2019 10:20 am
hello!
i am looking for analog modules being able to
-detect thru zero crossings
-distinguish/detect falling or rising (rectified) voltage
-detect if voltage changes over a certain threshold
Is a moving/dynamic/cv-controllable comparator doing all this? plus a rectifier? plus s&h?
Can you please recommend me modules in Eurorack format that are precisely adjustable?
adnauseam
Post by adnauseam » Fri Aug 16, 2019 10:58 am
Check out a series of modules by Ladik.
authorless
Post by authorless » Fri Aug 16, 2019 3:30 pm
"Precisely adjustable" doesn't really mean anything. You might need to be a little clearer in what you mean.
A slope detector will detect rising or falling slopes. Try Elby.
A comparator will detect if a voltage is over a threshold. Doepfer's works great for me.
A window comparator can be set up for zero-crossing detection. I don't know who is currently making a window comparator but one can be built from two comparators and an AND gate and a logic inverter if the comparator doesn't have a NOT output.
"Wait a month and buy from a fellow wiggler who's desperate for new modules." - Johnisfaster
"It's oscillators are so precise and lifeless it's actually a digital modelling analog synth." - nadafarms
cptnal
Post by cptnal » Fri Aug 16, 2019 4:00 pm
Check out the Joranalogue Compare 2 dual window comparator, and the Ladik Derviator - slope detector.
autopoiesis
Post by autopoiesis » Fri Aug 16, 2019 6:16 pm
it sounds like you're looking for the bastl dynamo
electricanada
Re: comparator? thru zero detection? increasing decrasing? E
Post by electricanada » Sat Aug 17, 2019 4:14 pm
lacuna wrote:hello!
Comparator detects voltage change relative to an adjustable threshold. Window comparators — such as Joranalogue’s — are more flexible.
Ladik derivator detects rising or falling.
c0rpse
Post by c0rpse » Sat Aug 17, 2019 5:12 pm
I haven't tried it yet, but this post made me realize you could do it with the WMD/SSF Toolbox.
-Rectifier for sending the cv to the non thru zero fm input
-Comparator for zero-crossing detection on the modulator.
-Invert for generating the inverted carrier output.
-Switch for switching between Normal and Inverted carrier signal.
[/b]
VINO MALO | Designer and Software Developer for WMD
sko87pro
Post by sko87pro » Mon Aug 19, 2019 4:53 pm
adnauseam wrote:Check out a series of modules by Ladik.
Have a look at the Ladik Derivator (J-110) and Comparator (J-120) in 4HP:
Derivator
J-110 Derivator (4HP)
http://ladik.ladik.eu/?page_id=1455
Comparator
J-120 Comparator (4HP)
http://ladik.ladik.eu/?page_id=1459
