IFM Grassi standalone
home of post-70s electronics
Moderators: Kent, bartlebooth
fluxmonkey
Post by fluxmonkey » Tue Aug 20, 2019 8:42 pm
i'm not a euro guy, but i made an exception for Mssr. Mobenthy, and i have a small rack with one of each, but sadly no room for the Grassi. it occurred to me that, if it's closely related to Mr. Grassi paper circuit it might not need a bipolar PS, and might even run on 9v battery power, which turned out to be the case! et so voila - standalone chaos control
www.fluxmonkey.com
BUILDER FOR HIRE - kits or custom, email me with your needs
jimmie
Post by jimmie » Tue Aug 20, 2019 9:28 pm
:tu: Mr. Grassi awesome :tu: I only wish all jacks had been located on the bottom or top for playability in the case of spaghetti :oops:
tenshun
Post by tenshun » Thu Aug 22, 2019 7:07 pm
thats really cool! if you dont mind me asking. how did you wire the 9volt battery connector to the pcb?
fluxmonkey
Post by fluxmonkey » Thu Aug 22, 2019 9:42 pm
tenshun wrote:thats really cool! if you dont mind me asking. how did you wire the 9volt battery connector to the pcb?
originally i just spliced it on to the power ribbon cable it came with. after this picture was taken, i went back and unsoldered the ribbon entirely and soldered directly to the pads, allowed me to use shorter spacers and generally tighten things up
www.fluxmonkey.com
cowboyelectronics
Post by cowboyelectronics » Tue Aug 27, 2019 3:55 pm
jimmie wrote::tu: Mr. Grassi awesome :tu: I only wish all jacks had been located on the bottom or top for playability in the case of spaghetti :oops:
Have you tried tendrils right angle cables? I could see them being particularly helpful with Mr. Grassi
fluxmonkey
Post by fluxmonkey » Tue Aug 27, 2019 4:12 pm
ooh, had not heard of those, hot tip: https://www.tendrilscables.com/shop/
www.fluxmonkey.com
SPIKE the Percussionist
Post by SPIKE the Percussionist » Wed Aug 28, 2019 2:04 am
neat!
good to know someone else is making right angle patch cables since Erthenvar closed up shop.
more noiz!
- http://www.manipulate.net -
ASTROGENIC HALLUCINAUTING
CoRE - Constructs of Ritual Evolution
DOGGEBI
Fiddle Witch and the Demons of Doom
morgue city
Unified Space
williamjturkel
Post by williamjturkel » Sun Nov 17, 2019 2:54 pm
Another Mr Grassi tip: for some patches you don’t need cables. Try touching it while your other hand is on Mocante, for example.
Return to “Ciat-Lonbarde”
