Found a great reverb!
evs
Post by evs » Fri Aug 23, 2019 10:02 am
i was searching for a nice reverb, for a small budget, and i found out the Lexicon Reflex is a unknown beauty. i got it on ebay for 30€.. which was pure luck. but also 100€ would not be too much.
it sounds super nice!
so this just as a small hint, when you search for a nice reverb unit, get one of these. lovely and a small secret so it seems!
Blingley
Post by Blingley » Fri Aug 23, 2019 9:06 pm
I don't exactly think Lexicon reverbs are unknown or secret. :hihi:
evs
Post by evs » Sat Aug 24, 2019 3:19 am
Yes of course, but the reflex seems to be... somehow...
jonne74
Post by jonne74 » Sat Aug 24, 2019 11:50 am
I have a Vortex and I believe they were released around the same time.
Post by MindMachine » Sat Aug 24, 2019 10:51 pm
I had the Reflex until the encoders went senile. Canyon and Resonator settings were all I used.
I also have the Vortex from the same series of budget effects.
They are actually very well known. But congrats that is a pretty good deal for a nice rack effect.
:guinness:
FS: Pedals and Euro modules, Delta Labs
viewtopic.php?f=74&t=233636&p=3287718&h ... e#p3287718
BLX
Post by BLX » Sun Aug 25, 2019 2:51 pm
it was my first "decent" reverb, and I agree its great and it still stands up in its own way. I particularly love the resonator setting and its midi controllable so you can bend it about a bit.
I still have it on an aux and it sits really well in mix compared to some of the more lush modern blue box type verbs.
https://soundcloud.com/blxmgc
Albums : The Crash Sessions (2018), Forres ( 2019)
calaveras
Post by calaveras » Sun Aug 25, 2019 5:45 pm
I think the Reflex is overlooked because it has such a corny name.
It's seen as one of those downmarket mistakes.
If it was two RU and had a number instead of a name people would dig it.
EPTC
Post by EPTC » Sun Aug 25, 2019 10:51 pm
Congrats - Lexicons are tremendous. You might want to open the Reflex up (should be easy enough) - Depending on the model, Lexicons have nickel cell batteries soldered to the board. It might use that for the 'learn' button — but maybe not (i have an mpx100 which is similar in design to the Reflex with very similar preset knobs, and there's no battery inside, but on my mpx1 there was one - until I got I removed the battery and put in a user replaceable holder for it)
Longstory short: If it has a battery on the board it's a bit of a time bomb, as it'll bleed onto the circuits if/when the battery fails. It's about $5 worth of parts to desolder the battery, replace with a battery holder instead to hold a regular cell battery. Bad design on Lexicon's part but an easy fix. If you get a tech to do it, should be just $50-75 or so.
Reflex's might not have batteries for memory but it's worth checking. I love Lexicon sounds. Enjoy!
http://www.ep.tc/spoken-word
SPOKEN WORD WITH ELECTRONICS #20: A Tribute to Anne Sexton
evs
Post by evs » Mon Aug 26, 2019 2:59 am
EPTC wrote:Congrats - Lexicons are tremendous. You might want to open the Reflex up (should be easy enough) - Depending on the model, Lexicons have nickel cell batteries soldered to the board. It might use that for the 'learn' button — but maybe not (i have an mpx100 which is similar in design to the Reflex with very similar preset knobs, and there's no battery inside, but on my mpx1 there was one - until I got I removed the battery and put in a user replaceable holder for it)
thanks for that tip! i will have a look!
sutekina bipu-on
Post by sutekina bipu-on » Mon Aug 26, 2019 7:36 am
Probably a good call to check out the cheaper Lexicons, i always noticed over the years when i'd buy rack gear that the racks full of "better" gear would often a couple Alex / Vortex / Reflex in the rack. I never gave them much thought though. There are a lot of great values in rack gear if you are happy to set aside some space to set it up.
cybotron
Post by cybotron » Tue Aug 27, 2019 12:03 pm
Nice find! A lot of the older Alesis reverbs are pretty cheap too.
coolshirtdotjpg
Post by coolshirtdotjpg » Thu Aug 29, 2019 10:20 am
cybotron wrote:Nice find! A lot of the older Alesis reverbs are pretty cheap too.
Midiverb II's still sound great if you're ok with using set sounds.
My favorite cheap rack reverb is the SPX90. I think I paid 90 USD for mine. That ones not exactly a hidden gem, but it's a great reverb for the price.
New video on Prophet 12 Drone Patches:
