A new panel design for the Deep Equinoxe
Synthbuilder
Post by Synthbuilder » Fri Aug 23, 2019 11:46 am
This one uses a single switch to select between the four, six and eight stage modes. The previous design uses two switches to do the same thing.
A special type of toggle switch is used called a SP3T and it pretty easy to wire up in a Deep Equinoxe build. The switch is available from Mouser and Digikey as NKK part numbers M2024ES1G01 or M2024ES1W01.
FPD databases for the new designs, in both natural and black, alongside the older two switch versions are available on the project webpage:
http://www.oakleysound.com/deep.htm
Tony
