ES 1 and Numerology
Moderators: Kent, os
Weston Underwood
ES 1 and Numerology
Post by Weston Underwood » Tue Sep 21, 2010 4:39 pm
Hi Os et al,
How do I get an ES1 setup for bipolar to work with numerology. I obviously can't use the SW AC plug in?
Or can I
Best wishes
Weston
bsmith
Post by bsmith » Tue Sep 21, 2010 4:49 pm
Yeah, you can use the AC plug - look under 'audio unit fx', it's there - just make sure you insert it directly after the voice controller (the one available available under audio unit fx, which is different than the audio unit synth one) and take a peek at the routing tab to make sure it is routed correctly - midi going into the voice controller, and then audio coming out of the voice controller into the ac encoder, which goes off to modular land.
jimAtFive12
Post by jimAtFive12 » Tue Sep 21, 2010 4:59 pm
I just got back from the synth meet in Chicago last night. I'll be testing the ES-1 in AC mode with Numerology this week. I'll post instructions as soon as I have it setup.
Jim
Return to “Expert Sleepers”
