Eurorack Mixer Ideas
Post by MindMachine » Mon Sep 02, 2019 12:56 am
oilpanic wrote:If I where to do it again I would pick the joranalogue mixer. Two of them.
What do you mean 'again'?
Petaluma, nice! I was in Mill Valley for a few years.
I use quite a few mixers for various functions but go out of the box with VCA's or my Erica Output module.
FS: Pedals and Euro modules, Delta Labs
viewtopic.php?f=74&t=233636&p=3287718&h ... e#p3287718
R.U.Nuts
Post by R.U.Nuts » Mon Sep 02, 2019 1:40 am
Arneb wrote:
cptnal wrote:
Arneb wrote:...sending audio at modular levels into your desktop mixer through 3.5mm-to-6.35mm TS jack adapters?
Exactly what I do with my Mackie VLZ4 (which I didn't include in my original list :ripbanana: ). In fact, with all the routing possibilities and a bunch of pedals, it's practically an extension of my rack. There's so issues with levels if that's what you're worried about. Just keep it low and work upwards. :tu:
Being able to handle modular levels is just one part of it, though. I mean, in my current 3U learning setup I do work with modular levels from ModDemix straight into an old DJ mixer I got for free from a friend decluttering their household. It works... with the fader at 20% in. Which makes for a pretty short usable fader range and a correspondingly sensitive fader. Which is why I'm currently doing the actual mixing work with ModDemix, not the DJ mixer.
(Ofc ModDemix isn't exactly a viable long-term solution either, except as part of a cascading setup.)
Doesn't that DJ mixer have input gain controls? Usually you can attenuate a modular signal with the built in channel preamps. I do gain staging in a way that I can slam the faders all the way up without clipping and it works fine if I set up the input gain correctly.
dopelganger
Post by dopelganger » Mon Sep 02, 2019 12:31 pm
Thanks! This is an awesome reference!!
I get mskala's point and in the studio that makes complete sense. But for performance its not really an option...
mdoudoroff wrote:Depending on your process there are many different ways to go, and with due respect to mskala, in many of them, a stereo mixer module can make a great deal of sense. It just depends.
Here’s a pretty exhaustive comparison list of the stereo mixer modules that are available:
https://doudoroff.com/mixers/
By no means does this comparison address all questions, but it’s probably a useful reference.
Arneb
Post by Arneb » Mon Sep 02, 2019 1:06 pm
That thing goes down to -10dB at the input gain stage, which is still too hot for using the faders as God intended. I don't really understand the math of this dBu/dBv/... stuff, would -20dB likely be enough?
dopelganger wrote:Thanks! This is an awesome reference!!
I'd say it still is, we're not talking about bringing an X32 after all. Somewhere between 6 and 12 channels ought to suffice and still be light enough for live gear.
steveoath
Post by steveoath » Mon Sep 02, 2019 3:25 pm
Rebel technology's mix range are great. I'll be picking up another mix module to complement the one I have ready. The link function is cool too.
ZenitSar
Post by ZenitSar » Mon Sep 02, 2019 5:40 pm
I use a Doepfer A-138p. It's cool because it's simple. I need to get another one because I need more channels. I'm mixing kick, snare, hihat, and a couple of voices atm. I like the send and send level control for delay use, but I kind of wish it had two sends. I thought about modding it to accommodate an individual out module that would be easy to make. It's cheap, but sturdy.
ZenitSar - Solo modular
CV - SciFi Rock
DJMaytag
Post by DJMaytag » Tue Sep 10, 2019 10:04 pm
It looks like it could be crazy expensive, but the Frap Tools CGM system looks really nice. I don't need the EQ's, so this is a good way to start a system for me: buy the Group and a couple channel modules, then add a master and additional channels later. I'd rather drop $200 several times than drop $800 or $1000 all at once.
Instagram | Soundcloud | Wisco Wigglers
If you talk about improper grounding 3 times, Graham Hinton appears!” -djs
