FH-2 MPE Unison mode note-off and gates
Author FH-2 MPE Unison mode note-off and gates
mrMagenta
Hello Os!
I would like to use MPE with the unison voice allocation scheme, but legato playing is not possible as it is (fw 1.7.2). When the converter receives a note-off it cuts out the gates regardless if keys are still pressed down. Even note-offs from older released keys cut out the latest active note.
I wish that the converter would keep an active note stack and the gates of all voices would stay on as long as one or more keys are still held down, where the newest active note sets the pitch and expression values of all the the voices.
This would serve as a deluxe monophonic playing mode where pitch, pressure and y-axis values are tracked per note the same way as pitch functions in a regular MIDI monophonic scheme. I have some patch ideas where this would make things really come alive and the responsiveness could be tweaked using the smoothing options that are already in place. I'm thinking it would be a powerful feature.
Cheers!
Unison mode and MPE don't really play well together at the moment. I'll make a note to look into that.
mrMagenta
Thanks Os!
Btw, is there a way to have a panic / all notes off button assigned to the small left button on FH-2?
This would be a big help in random stuck note situations
Yes, I could do that.
mrMagenta
Awesome!
Sorry to pile up a ton of requests. I thought of another thing that would be useful if possible.
It would be nice if there was a way to send a user defined sysex command when loading/switching presets.
This would allow for switching MIDI gear configurations between presets.
In my case I'd be sending Roli units a line to switch between MPE and single channel modes, setting the current octave, piano mode on/off etc.
There's a whole host of useful commands for setting up Roli Seaboard blocks by sysex, here's a list I found on the Roli support forum in case anyone else here is interested and also trying to use these in a computerless rig.
    Modes:
    MPE F0 00 21 10 77 2E 10 20 20 00 00 00 00 00 38 F7
    Multi F0 00 21 10 77 2E 10 20 00 00 00 00 00 00 58 F7
    Single F0 00 21 10 77 2E 10 20 40 00 00 00 00 00 18 F7
    Chan 1 F0 00 21 10 77 2E 10 00 20 00 00 00 00 00 18 F7
    Chan 2 F0 00 21 10 77 2E 10 00 40 00 00 00 00 00 78 F7
    Chan 3 F0 00 21 10 77 2E 10 00 60 00 00 00 00 00 58 F7
    Chan 4 F0 00 21 10 77 2E 10 00 00 01 00 00 00 00 09 F7
    Chan 5 F0 00 21 10 77 2E 10 00 20 01 00 00 00 00 69 F7
    Chan 6 F0 00 21 10 77 2E 10 00 40 01 00 00 00 00 49 F7
    Chan 7 F0 00 21 10 77 2E 10 00 60 01 00 00 00 00 29 F7
    Chan 8 F0 00 21 10 77 2E 10 00 00 02 00 00 00 00 5A F7
    Chan 9 F0 00 21 10 77 2E 10 00 20 02 00 00 00 00 3A F7
    Chan 10 F0 00 21 10 77 2E 10 00 40 02 00 00 00 00 1A F7
    Chan 11 F0 00 21 10 77 2E 10 00 60 02 00 00 00 00 7A F7
    Chan 12 F0 00 21 10 77 2E 10 00 00 03 00 00 00 00 2B F7
    Chan 13 F0 00 21 10 77 2E 10 00 20 03 00 00 00 00 0B F7
    Chan 14 F0 00 21 10 77 2E 10 00 40 03 00 00 00 00 6B F7
    Chan 15 F0 00 21 10 77 2E 10 00 60 03 00 00 00 00 4B F7
    Chan 16 F0 00 21 10 77 2E 10 00 00 04 00 00 00 00 7C F7
    MIDIStart 1 F0 00 21 10 77 2E 10 00 20 00 00 00 00 00 18 F7
    MIDIStart16 F0 00 21 10 77 2E 10 00 00 04 00 00 00 00 7C F7
    MIDIEnd 1 F0 00 21 10 77 2E 10 10 20 00 00 00 00 00 28 F7
    MIDIEnd 16 F0 00 21 10 77 2E 10 10 00 04 00 00 00 00 0C F7
    MPELowZone F0 00 21 10 77 2E 10 00 05 00 00 00 00 00 77 F7
    MPEUpZone F0 00 21 10 77 2E 10 00 25 00 00 00 00 00 57 F7
    MPENumChn 1 F0 00 21 10 77 2E 10 10 21 00 00 00 00 00 1B F7
    MPENumChn 2 F0 00 21 10 77 2E 10 10 41 00 00 00 00 00 7B F7
    MPENumChn15 F0 00 21 10 77 2E 10 10 61 03 00 00 00 00 4E F7
    Bend 0 F0 00 21 10 77 2E 10 30 00 00 00 00 00 00 68 F7
    Bend 1 F0 00 21 10 77 2E 10 30 20 00 00 00 00 00 48 F7
    Bend 2 F0 00 21 10 77 2E 10 30 40 00 00 00 00 00 28 F7
    Bend 4 F0 00 21 10 77 2E 10 30 00 01 00 00 00 00 39 F7
    Bend 24 F0 00 21 10 77 2E 10 30 00 06 00 00 00 00 4E F7
    Bend 96 F0 00 21 10 77 2E 10 30 00 18 00 00 00 00 00 F7
    Octave -4 F0 00 21 10 77 2E 10 40 00 7F 7F 7F 7F 03 03 F7
    Octave -3 F0 00 21 10 77 2E 10 40 20 7F 7F 7F 7F 03 63 F7
    Octave -2 F0 00 21 10 77 2E 10 40 40 7F 7F 7F 7F 03 43 F7
    Octave -1 F0 00 21 10 77 2E 10 40 60 7F 7F 7F 7F 03 23 F7
    Octave 0 F0 00 21 10 77 2E 10 40 00 00 00 00 00 00 78 F7
    Octave 1 F0 00 21 10 77 2E 10 40 20 00 00 00 00 00 58 F7
    Octave 2 F0 00 21 10 77 2E 10 40 40 00 00 00 00 00 38 F7
    Octave 3 F0 00 21 10 77 2E 10 40 60 00 00 00 00 00 18 F7
    Octave 4 F0 00 21 10 77 2E 10 40 00 01 00 00 00 00 49 F7
    Octave 5 F0 00 21 10 77 2E 10 40 20 01 00 00 00 00 29 F7
    Octave 6 F0 00 21 10 77 2E 10 40 40 01 00 00 00 00 09 F7
    Transp -11 F0 00 21 10 77 2E 10 50 20 7D 7F 7F 7F 03 51 F7
    Transp -10 F0 00 21 10 77 2E 10 50 40 7D 7F 7F 7F 03 31 F7
    Transp 0 F0 00 21 10 77 2E 10 50 00 00 00 00 00 00 08 F7
    Transp 11 F0 00 21 10 77 2E 10 50 60 02 00 00 00 00 4A F7
    Slide CC 0 F0 00 21 10 77 2E 10 60 00 00 00 00 00 00 18 F7
    Slide CC 1 F0 00 21 10 77 2E 10 60 20 00 00 00 00 00 78 F7
    Slide CC127 F0 00 21 10 77 2E 10 60 60 1F 00 00 00 00 07 F7
    Absolute F0 00 21 10 77 2E 10 70 00 00 00 00 00 00 28 F7
    Unipolar F0 00 21 10 77 2E 10 70 20 00 00 00 00 00 08 F7
    Bipolar F0 00 21 10 77 2E 10 70 40 00 00 00 00 00 68 F7
    Piano Off F0 00 21 10 77 2E 10 10 02 00 00 00 00 00 2E F7
    Piano On F0 00 21 10 77 2E 10 10 22 00 00 00 00 00 0E F7
    Glide 0 F0 00 21 10 77 2E 10 20 02 00 00 00 00 00 3E F7
    Glide 1 F0 00 21 10 77 2E 10 20 22 00 00 00 00 00 1E F7
    Glide 127 F0 00 21 10 77 2E 10 20 62 1F 00 00 00 00 2D F7
    GlideLk Off F0 00 21 10 77 2E 10 30 02 00 00 00 00 00 4E F7
    GlideLk On F0 00 21 10 77 2E 10 30 22 00 00 00 00 00 2E F7
    Chord Off F0 00 21 10 77 2E 10 00 03 00 00 00 00 00 11 F7
    Chord Oct F0 00 21 10 77 2E 10 00 23 00 00 00 00 00 71 F7
    Chord m7b5 F0 00 21 10 77 2E 10 00 43 03 00 00 00 00 44 F7
    Chord options: Off Octave 5th Major minor Sus4 Sus2 7th Major7 Minor7 9th Minor9 diminished Augmented m7b5
    Glide Trk 1 F0 00 21 10 77 2E 10 60 23 00 00 00 00 00 51 F7
    Glide Trk 2 F0 00 21 10 77 2E 10 60 43 00 00 00 00 00 31 F7
    Glide Trk 3 F0 00 21 10 77 2E 10 60 63 00 00 00 00 00 11 F7
    Glide Trk 4 F0 00 21 10 77 2E 10 60 03 01 00 00 00 00 42 F7
    Glide Tracking Mode: Last Played, Highest, Lowest, Disabled
    Slide Trk 1 F0 00 21 10 77 2E 10 70 23 00 00 00 00 00 61 F7
    Slide Trk 2 F0 00 21 10 77 2E 10 70 43 00 00 00 00 00 41 F7
    Slide Trk 3 F0 00 21 10 77 2E 10 70 63 00 00 00 00 00 21 F7
    Slide Trk 4 F0 00 21 10 77 2E 10 70 03 01 00 00 00 00 52 F7
    Slide Tracking Mode: Last Played, Highest, Lowest, Disabled
    Press Trk 1 F0 00 21 10 77 2E 10 00 04 00 00 00 00 00 04 F7
    Press Trk 2 F0 00 21 10 77 2E 10 00 24 00 00 00 00 00 64 F7
    Press Trk 3 F0 00 21 10 77 2E 10 00 44 00 00 00 00 00 44 F7
    Press Trk 4 F0 00 21 10 77 2E 10 00 64 00 00 00 00 00 24 F7
    Press Trk 5 F0 00 21 10 77 2E 10 00 04 01 00 00 00 00 55 F7
    Press Trk 6 F0 00 21 10 77 2E 10 00 24 01 00 00 00 00 35 F7
    Pressure Tracking Mode: Multi-Channel, Last Played, Highest, Lowest, Disabled, Hardest
    Str Sens 0 F0 00 21 10 77 2E 10 20 01 00 00 00 00 00 4B F7
    Str Sens127 F0 00 21 10 77 2E 10 20 61 1F 00 00 00 00 3A F7
    Gli Sens 0 F0 00 21 10 77 2E 10 30 01 00 00 00 00 00 5B F7
    Gli Sens127 F0 00 21 10 77 2E 10 30 61 1F 00 00 00 00 4A F7
    Sli Sens 0 F0 00 21 10 77 2E 10 40 01 00 00 00 00 00 6B F7
    Sli Sens127 F0 00 21 10 77 2E 10 40 61 1F 00 00 00 00 5A F7
    Prs Sens 0 F0 00 21 10 77 2E 10 50 01 00 00 00 00 00 7B F7
    Prs Sens127 F0 00 21 10 77 2E 10 50 61 1F 00 00 00 00 6A F7
    Lft Sens 0 F0 00 21 10 77 2E 10 60 01 00 00 00 00 00 0B F7
    Lft Sens127 F0 00 21 10 77 2E 10 60 61 1F 00 00 00 00 7A F7
    Vel 1 F0 00 21 10 77 2E 10 00 22 00 00 00 00 00 7E F7
    Vel 2 F0 00 21 10 77 2E 10 00 42 00 00 00 00 00 5E F7
    Vel 127 F0 00 21 10 77 2E 10 00 62 1F 00 00 00 00 0D F7
    FixedVelOff F0 00 21 10 77 2E 10 70 01 00 00 00 00 00 1B F7
    FixedVelOn F0 00 21 10 77 2E 10 70 21 00 00 00 00 00 7B F7
