EURO: DIY Stereo Delay
Post your patches here! Put the format(s) in the subject.
cptnal
Post by cptnal » Tue Sep 03, 2019 5:03 am
Not sure if this comes under stating-the-bleeding-obvious, but here's a sub-patch that's been bringing me much joy lately, and saving me :75: on a dedicated module into the bargain.
We're creating a stereo delay with two Distings and their many delay algorithms, and a matrix mixer. The delays are set with no feedback of their own, and the wet-only outputs go back into the mixer. The patch I have going at the moment uses the mono clocked delay algorithm, and the return from each delay is fed back to the input of the other. With the delays clocked at different divisions this creates lots of interesting repeats depending on the trigger pattern at the input.
You can also get some nice stereo chorus and tape warble effects using the VC delay line algorithm. Next to explore is putting some filters (or something else) in the feedback path, and using the SD delays to achieve some ping-pong loops, which could be interesting...
The only thing it's missing is a reverse option, but at the rate Os releases firmware patches who knows what the future may bring? :cloud:
Is it finished?
Latest Tune:
Sounds: SoundCloud , Freesound
Racks: Big Case, Skiff, Waveform Laboratory, Funboat
MuadMusic
Re: EURO: DIY Stereo Delay
Post by MuadMusic » Thu Aug 20, 2020 8:32 am
Clever idea. The possibilities with modular are practically endless. IMHO, delay is more critical than reverb to a modular system.
Here's a very early implementation of delay that I created using the new Daisy DSP processing board:
The implementation has been cleaned up significantly since then.
Return to “Synthesis Techniques”
