a question about outboard gears with different voltages
ipnoteca
cane morto
Post by ipnoteca » Wed Sep 04, 2019 9:37 am
long story short,
i live in japan an i am in the process of buying some studio equipment,
most of the gear i am eyeing is rated 115/230v while in japan electricity is mainly 100v, only one it requires 120v, luckily all the gear works both on 50/60hz
now, do i need a step up converter in order to avoid damage?
eventually what's the worst could happen i plug in straight as it is?
as far as i understand worse it can happen is that said equipment will not work at 100% of its potentiality.
anything similar to possibly a rack or a "pedal power supply" with different selectable voltage output exitst?
thank you in advance for your help!
i've blown a fuse...
previously robocoder
YOUTUBE http://www.youtube.com/user/ipnoteca
INSTAGRAM http://www.instagram.com/ipnoteca/
