FH-2 Euclidean Output Voltage Question
Author FH-2 Euclidean Output Voltage Question
javes777
Hi Os,
Quick question - if I have the FH-2 set to 0 to 10 v - the Euclidean Output trigger works fine (goes from 0 to 10 on the triggers), but if I set the range to -/+ 5 v, the trigger outputs -5 to 0 and therefore is not triggering my modules. Is there any setting where I could specify 0 to + 5 tiggers while using the -/+ 5 v range setting?
I'm using the FH-1 as an expander, and changing ranges is not quick, as you know. smile
Thanks in advance.
It uses the gate levels defined in the configuration.
javes777
Thanks Os.
I re-read that section of the manual and it now makes perfect sense.
