Patching a Notch Filter from a Bandpass
Post your patches here! Put the format(s) in the subject.
c0rpse
Post by c0rpse » Wed Sep 04, 2019 5:16 pm
I figured that if I subtracted a bandpass signal from the dry signal I would get a notch. Apparently this is not the case because of phase alignment.
Instead you must put the bandpass in a feedback loop on the subtractor.
Code: Select all
 INPUT+------->+     |
               | SUM +------------+--> OUT
+--+ INVERT +<-----+ BANDPASS +<--+
It's a pretty basic concept, but this forum section can use some love.
VINO MALO | Designer and Software Developer for WMD
damase
Post by damase » Wed Sep 04, 2019 5:39 pm
nice one, thanks
hinterlands303
Post by hinterlands303 » Fri Oct 04, 2019 6:57 pm
I gave this a go last night with an Intellijel uVCF and Happy Nerding MIA (to do the summing and inverting) and it sounded great! Thanks for the tip.
authorless
Re: Patching a Notch Filter from a Bandpass
Post by authorless » Thu Dec 26, 2019 2:35 pm
The filter you are using is probably already inverting the signal, have you tried summing the filter output with the original signal without inverting either?
"Wait a month and buy from a fellow wiggler who's desperate for new modules." - Johnisfaster
"It's oscillators are so precise and lifeless it's actually a digital modelling analog synth." - nadafarms
Return to “Synthesis Techniques”
