Where do you guys buy parts in bulk, particularly pots?
jpeterman
Post by jpeterman » Wed Sep 04, 2019 8:10 pm
I'm talking about the Alpha 9mm pots with round shaft.
https://synthcube.com/cart/alpha-9mm-ro ... mount-pots
Is there any where to buy these pots thats cheaper than the usual suspects? I.E. Synthcube, ModularAddict, Thonk
The ones on ali express are best $2/peice which is actually more than synthcube :hmm:
ranix
Post by ranix » Wed Sep 04, 2019 8:18 pm
thetwlo
Post by thetwlo » Wed Sep 04, 2019 10:13 pm
pretty sure they do not.
where? link? :despair:
sduck
experimental use of gravity
Post by sduck » Wed Sep 04, 2019 10:23 pm
Here's the mouser # for the 100K linear version of the 9mm knurled shaft pot - 317-2090F-100K - not round shaft, but will work in a pinch. You can search for similars from there.
infinitemachinery
Post by infinitemachinery » Wed Sep 04, 2019 10:27 pm
If you're buying pots in bulk, Thonk is where I'd go. They have the right styles of pots and decent bulk discount prices.
ranix
Post by ranix » Wed Sep 04, 2019 11:00 pm
thetwlo wrote: pretty sure they do not.
ah sorry, I didn't actually check for the 9mm round pot. I just saw they carried alpha pots and said "oh they have them"
nigel
Post by nigel » Wed Sep 04, 2019 11:17 pm
Tayda
cygmu
Post by cygmu » Thu Sep 05, 2019 12:56 am
sduck wrote:Here's the mouser # for the 100K linear version of the 9mm knurled shaft pot - 317-2090F-100K - not round shaft, but will work in a pinch. You can search for similars from there.
I think those are the plastic shaft type with no mounting thread on the bushing, though I will admit to being confused by the pictures in the datasheet so could definitely be wrong.
Edit: I think these are the typical pots that are supplied by Thonk, Tayda etc.
RD901F-40-15R1-B10K-00DL1
Not cheaper at Mouser. In fact, considerably more expensive!
ixtern
Post by ixtern » Thu Sep 05, 2019 1:32 am
I ussually buy in Thonk. Once I've bought in Mouser wrong pots (or encoders, don't remember) because they have wrong description (shaft type or so) and I didn't check datasheet. Never trust in Mouser descriptions, always check datasheet.
cackland
Post by cackland » Thu Sep 05, 2019 1:43 am
I've been sussing out bulk purchase of pots through Song Huei, although there MOQ is 1000 dammit. Otherwise each HQ metal pot is around $0.35USD.
Was thinking of doing a larger purchase order if anyone is interested.
Otherwise I go through Thonk also.
thetwlo
Post by thetwlo » Thu Sep 05, 2019 2:01 am
I actually don't think any of these posts have linked to a source for the pots in the OP.
These have never been cheap or common/easy to find SmallBear has them but even more $$. ...more than they used to be:
http://smallbear-electronics.mybigcomme ... -pc-mount/
FetidEye
demonic space drone
Post by FetidEye » Thu Sep 05, 2019 2:28 am
ebay. I had good results. 0,30 ct p/p
search for RK097N
jpeterman
Post by jpeterman » Thu Sep 05, 2019 2:48 am
FetidEye wrote:ebay. I had good results. 0,30 ct p/p
search for RK097N
Those are 15mm and knurled (knurled is fine but 15mm not so much)
ixtern
Post by ixtern » Thu Sep 05, 2019 3:29 am
search for RK097N
15 mm is enough for panel mount. Longer are sometimes needed when PCB mounted and densely packed (for low-diameter knobs). At least it is from my experience.
Troubleshooter
Post by Troubleshooter » Thu Sep 05, 2019 9:06 am
I buy my 16mm @ Musikding.de
5 1,00 €
10 0,92 €
25 0,85 €
50 0,82 €
Always great quality if you look for a slow, tight but smooth feel if you know what I mean. Not recomended for DJ-stuff you want to operate fast. Great for parameter set knobs.
AudioElectronicsAcademy
Post by AudioElectronicsAcademy » Thu Sep 05, 2019 10:09 am
I usually but them for Prototyping at THONK:
https://www.thonk.co.uk/shop/alpha-9mm- ... ght-angle/
since they have the BEST mid-priced options (values, build-options).
After that I'll search the parts on aliexpress (look for RK097N) find a supplier
which has more values/options on stock (even if they don't have the one type I'm looking for) and write them directly and ask for a quote.
In my experience most of them will get you almost anything if a certain threshold (roughly 200USD, depending) is reached. If you're under that, they say no-sorry, we don't have / cannot / etc.
devinw1
Post by devinw1 » Thu Sep 05, 2019 10:49 am
Define bulk for you. If you are willing to buy 500+ there are ways (going to the manufacturer). The one that cackland mentioned is one. In fact you can just go right to Alpha for 1000 pieces too and it will be a lot cheaper than retail.
I don't know of any manufacturers that do less than 500 MOQ though. You're kind of stuck with retail for that.
keninverse
Post by keninverse » Thu Sep 05, 2019 11:12 am
BI Tech P09s can be purchased at around $0.60/ea in trays of 25 from TTI. They're conductive plastic and will last 10x more than alpha and have better tempcos. They have a smoother feel also but some people aren't happy with them being that they require less rotational torque to move.
ersatzplanet
Synthwerks Design
Post by ersatzplanet » Thu Sep 05, 2019 11:41 am
cackland wrote:I've been sussing out bulk purchase of pots through Song Huei, although there MOQ is 1000 dammit. Otherwise each HQ metal pot is around $0.35USD.
We bought our pots from Sung Huei (R1212N-b50K, L-20 F/M) and have some to spare. How many are you thinking of getting? I would have to talk to my money guy and see how much to charge for them. I'm in Seattle so shipping would be from there.
-James
sduck
Post by sduck » Thu Sep 05, 2019 11:53 am
Yes, mouser has their images all screwed up for these parts. And yes, I think your link is the best you're going to do on mouser, but it's hard to tell, as the data sheet for those is also screwed up. FWIW I never get these from mouser, I use tayda or smallbear.
J3RK
Post by J3RK » Thu Sep 05, 2019 2:25 pm
Mouser, Thonk, Synthcube, Modular Addict, Tayda, Small Bear. I buy pots from all of these. It mainly depends on what else I need to get at the time.
jimfowler
Post by jimfowler » Thu Sep 05, 2019 5:36 pm
Another vote for Small Bear. They do bulk discounts as well.
cackland
Post by cackland » Thu Sep 05, 2019 6:44 pm
Thanks for the offer. I'm looking at the 9mm series (RK0952N & RK0952G-1). Already have samples from them so may just bite the bullet.
