Disting Scrub Algorithm I6
Author Disting Scrub Algorithm I6
jamos
Well I am having a hell of a time getting the Scrub algorithm to work. I have been using algorithm I5 with no problem, but I6 does not give me results that make sense.
The list of folders in playlist.txt:
Propaganda
Religion
Pipes
Again, I can use these folders predictably in I5, but in I6
- The files in Propaganda make no sound; Y has no effect.
- Religion plays a contnuous high-pitched loop (that eventually stops); Y input has no apparent effect
- Pipes plays some sort of loop; Y seems to move the start point in a glitchy way.
Is there something odd about I6? Are the reversed files created by I5 compatible with I6 or are they confusing the algorithm?
WAV files created by Adobe Auction, some version from the turn of the century.
Help?
Seems to be working for me, though I did just find a problem where playback will stop if the Y voltage goes too high or low. I'll fix that.
jamos
Thanks, will try again tonight with 4.13 and your "known good" example files.
