Moog Grandmother tuning question
Blairio
Post by Blairio » Wed Sep 04, 2019 11:29 pm
Could I ask a favour of a Moog Grandmother owner / user please?
Could you check whether with the second oscillator's tuning turned full clockwise, the second oscillator is playing a perfect 5th against the first one with no 'beating' at all.
On mine, the second oscillator doesn't quite reach the perfect 5th (it is very slightly flat), so I am getting some 'beating' against the first one, and the 5th isn't really ringing clearly.
It may seem a minor point, but it is taking the polish off a part I'm trying to record at present, and before I go down the pot calibration route, I'd like to know if a perfect 5th is even achievable.
Thanks in advance to someone who can help.
Josef_K
Post by Josef_K » Thu Sep 05, 2019 12:17 am
I'll try to remember to check later, but a quick way around it is to boost the OSC 2 pitch with the attenuator/offset module. As long as that (and the OSC2 pitch in) isn't occupied already it should work fine. Of course it's not as elegant, but it's a solution.
Blairio
Post by Blairio » Thu Sep 05, 2019 1:06 am
Josef_K wrote:I'll try to remember to check later, but a quick way around it is to boost the OSC 2 pitch with the attenuator/offset module. As long as that (and the OSC2 pitch in) isn't occupied already it should work fine. Of course it's not as elegant, but it's a solution.
Good point! Earlier I was considering hooking my GM up to an offset module in my modular rig, but as you say, the onboard one should do nicely.
The more I think of it, the more I reckon I need to run the pot / mod wheel calibration routine. I think I am simply not accessing the available full range of the (digitally controlled) tuning pot.
Thanks,
Blair
Blairio
Post by Blairio » Fri Sep 06, 2019 8:55 am
Update: I ran the GM calibration routine three times, and on conclusion of the 3rd run, the oscillator 2 tuning control delivers a perfect 5th when turned fully clockwise.
Result.
Xmit
Post by Xmit » Fri Sep 06, 2019 9:11 am
I should probably run the tuning calibration on mine then - a perfect 5th for Osc 2 is a fair bit shy of fully clockwise on mine.
Blairio
Post by Blairio » Fri Sep 06, 2019 9:25 am
Xmit wrote:I should probably run the tuning calibration on mine then - a perfect 5th for Osc 2 is a fair bit shy of fully clockwise on mine.
So it sounds like your oscillator 2 tuning calibration is out in the opposite direction from mine - I couldn't reach the 5th, whereas you seem to be going past it.
As I say, it took 3 goes, but everything is hunky dory now.
