Plaits level problem
jbje
Post by jbje » Tue Sep 10, 2019 11:03 am
Hi. I just got my second Plaits module off Ebay, this one a black clone. It seems to work perfectly well, except the green synthesis models, which on my original Plaits has a constant output, on this one are all quiet when nothing is coming into the Trig or Level inputs. Except, strangely enough, for the very last mode, which has a faint sound to it. If I give it a cv signal on Level or a gate on Trig, it will sound. But is there something, some hidden menu I am missing?
Thanks in advance, for any advice you can give me.
Agawell
Post by Agawell » Tue Sep 10, 2019 12:25 pm
I take it your other one is a factory build and that you have tried the exact same settings on both and the factory one is producing audio and the clone is not?
and everything else works perfectly?
in that case it is most likely a problem with either the trigger or level input jack
if you put a dummy cable into one of these the drone will cut - so a current goes through those jacks and is switched out when one is inserted
it's most likely that mechanism that's not working properly - maybe one of the jacks is faulty or there's a bad solder joint between the voltage source and those jacks
probably very close to the jacks as everything else appears to be working fine
Instagram
Utility modules are the inexpensive, dull polish that makes the expensive, shiny modules actually shine - and stops them tarnishing too!!!
jbje
Post by jbje » Tue Sep 10, 2019 12:34 pm
Thanks, yes that's what I'm thinking as well. Unfortunately I'm rubbish with a soldering iron.
I have discovered another problem though: the MODEL input is unresponsive.
Yes, A/B'ed everything with my factory built, and those are the problems.
This is my first purchase of a DIY module, and I feel a bit discouraged now :(
Thanks for your reply.
Agawell wrote:I take it your other one is a factory build and that you have tried the exact same settings on both and the factory one is producing audio and the clone is not?
Agawell
Post by Agawell » Tue Sep 10, 2019 6:13 pm
I would contact the seller and ask them to fix or refund
Instagram
