Best modules for glitch sounds ?
Tomorrow Sounds Good
Post by Tomorrow Sounds Good » Tue Sep 10, 2019 8:18 pm
I’m new to eurorack , I’m currently looking at Morphagene but if anybody has any recommendation that would be great
Zymos
Post by Zymos » Tue Sep 10, 2019 8:20 pm
Check out the Møffenzeef line.
Post by Tomorrow Sounds Good » Tue Sep 10, 2019 8:46 pm
Ok thanks :bananaguitar:
SavageMessiah
Post by SavageMessiah » Tue Sep 10, 2019 8:57 pm
The new X1L3 Underwurlde is glitchy as hell, there's gate inputs and manual buttons to screw with the memory for the delay.
Pighood
Post by Pighood » Tue Sep 10, 2019 10:45 pm
SavageMessiah wrote:The new X1L3 Underwurlde is glitchy as hell, there's gate inputs and manual buttons to screw with the memory for the delay.
I have their Shard...a loofah of horror.
Other glitchbitches: Benjolin, Noise Swash.
*phnert*
sutekina bipu-on
Post by sutekina bipu-on » Tue Sep 10, 2019 10:47 pm
Anything Beast Tek really... and the Hypster!
motorhead412
Post by motorhead412 » Tue Sep 10, 2019 10:57 pm
I like the 2hp Freez and the Freeze function on the Qu-Bit Prism. I imagine you could also use the Hold function on the Mimeophon.
Not that you asked about pedals but, lately I've been trying a Malekko Charlie Foxtrot into a TKOG Mini Glitch. Definitely crazy in a good way.
Post by lisa » Tue Sep 10, 2019 11:03 pm
2hp Freez and Comb, Qu-bit Prism, Recovery Effects and Devices Cutting Room Floor V2, Synthrotek DIRT Filter.
New track! Drum synthesis heavy, melodic piece where Instruō harmonàig is doing the chords. 🐡
Post by Tomorrow Sounds Good » Tue Sep 10, 2019 11:54 pm
Thanks for the replies , will check them all out :sb:
squished
Post by squished » Wed Sep 11, 2019 12:19 am
+1 here for Prism. It does a great job at processing drums and percussive sounds. Also find my self using it solely as a stereo filter quite often.
Aside from the decimator, it does share similarities with the mimeophon, that might be a more interesting option, depending on what you’re after.
nectarios
Post by nectarios » Wed Sep 11, 2019 12:41 am
(u)Clouds/Monsoon with Kammerl firmware.
bemushroomed
Post by bemushroomed » Wed Sep 11, 2019 12:45 am
i went with monsoon + Kammerl instead of the way more expensive Morphagene.. pretty sure it's even better than morphagene at this particular task.
ggillon
Post by ggillon » Wed Sep 11, 2019 2:21 am
A bitcrusher
moremagic
Post by moremagic » Wed Sep 11, 2019 2:32 am
mn echophon has wonderful warbles when you adjust the delay time or send it an unsteady clock; delightful to send into the 2hp freze
Orange
Post by Orange » Wed Sep 11, 2019 4:36 am
Upcoming.
R.U.Nuts
Post by R.U.Nuts » Wed Sep 11, 2019 4:45 am
4MS DLD with random CV into delay time and random gates into delay feed, reverse and hold.
kinkycables
Post by kinkycables » Wed Sep 11, 2019 11:30 am
Trogotronic stuff. Dark Matter. MATHS. brst.
deftinwulf
Post by deftinwulf » Wed Sep 11, 2019 2:33 pm
bemushroomed wrote:i went with monsoon + Kammerl instead of the way more expensive Morphagene.. pretty sure it's even better than morphagene at this particular task.
I have Monsoon with Parasite firmware, but Kammerl is interesting.
Do you know if the Looping Delay mode on it is copied/borrowed from Parasite, or is it unique? Looping delay is the mode I use my Monsoon in most, but it would be great to have that plus the Kammerl modes.
I'm also considering picking up a Prism...
circuitburst
Post by circuitburst » Wed Sep 11, 2019 2:41 pm
Adding E950 Circuit Bent VCO by Synthesis Technology. Lots of glitch possible with this module, especially in circuit bent mode.
http://synthtech.com/eurorack/E950/
"make the events occur that you want to occur" - the black dog
https://soundcloud.com/circuitburst
https://www.modulargrid.net/e/racks/view/295055
:boat: World Map of Eurorack Module Manufacturers: https://www.google.com/maps/d/u/0/viewe ... 9IMDP34-ao
World Map of Eurorack Module Physical Shops: https://www.google.com/maps/d/u/0/viewe ... gfSeJ6wVIG
nectarios
Post by nectarios » Wed Sep 11, 2019 2:49 pm
Kammerl firmware has the original Looping Delay mode...which is a bummer and the reason I added a uClouds with Parasites to my factory Clouds with Kammerl firmware.
mritenburg
Post by mritenburg » Wed Sep 11, 2019 2:59 pm
There are lots of good suggestions here, but I might add that developing the patching skill to create glitch sound using basic patching techniques with basic modules should be one of your goals.
Disappointment with any module is usually a failure of imagination.
Ummm, I guess you would call it techno.
Funky40
Post by Funky40 » Wed Sep 11, 2019 3:18 pm
mritenburg wrote:There are lots of good suggestions here, but I might add that developing the patching skill to create glitch sound using basic patching techniques with basic modules should be one of your goals.
agreed !
was about to say something similar.
agreed on the DLD !
microcell and supercell might have parasites looping delay + kammerl in one module ( not shure, i never use the looping delay)
For sale:........it won´t sell, so i stopp bother you ;)
nectarios
Post by nectarios » Wed Sep 11, 2019 3:23 pm
+1 on the DLD. The fact it does not do the tape delay pitch wobble, helps getting glitch like stuff out of it.
Like the stuff after 0:52 if the video below:
c0rpse
Post by c0rpse » Wed Sep 11, 2019 4:04 pm
Assimil8or + anything is my go to.
VINO MALO | Designer and Software Developer for WMD
brandonlogic
Post by brandonlogic » Wed Sep 11, 2019 5:14 pm
The dld is great, one of my favorite modules in eurorack. But! For glitched out delays, sampling and granular, you really can’t beat the Reflex Liveloop!!!
It’s AMAZING for this task.
Interface is a little weird but worth it for the glitched out sounds you get out of it!
