The Sequarallel MIDI2CV Recorder+Sequencer
Would you use this module to:
Play Sequences to MIDI synths
13%
 13%  [ 3 ]
Play Sequences to VCO's
13%
 13%  [ 3 ]
Just a MIDI to CV converter
0%
 0%  [ 0 ]
With a High Clock Division to CV offset other sequencers
0%
 0%  [ 0 ]
Live Record from MIDI keyboard/controller
13%
 13%  [ 3 ]
Use MIDI CC's to make clocked LFO patterns
4%
 4%  [ 1 ]
All of the above
47%
 47%  [ 11 ]
None of the above
8%
 8%  [ 2 ]
Total Votes : 23
Author The Sequarallel MIDI2CV Recorder+Sequencer
Sandrine
Hi! This is Sandy from SDS Digital with a brand new module called Sequarallel. It is to be part of the Accord series the upcoming Melisma module inspired.
We have decided to go ahead and produce the Sequarallel module!
Here's the main points of the module
(edited Sept 29, real module prototype)
MAIN USES:
-A MIDI to CV convertor
-A MIDI Sequencer / Looper
-A 4 Track Gate/CV Sequencer
-A 12 Trigger Drum Sequencer
-A Clocked MIDI Controller Recorder
-A MIDI in + Sequence Merger
-A Clocked Live MIDI Recorder
-A CV to MIDI convertor
-A MIDI to modular clock source
-A modular clock to MIDI clock
RECORD:
Record a sequence from DAW as a song-like sequence (with up to 8 Loop markers). Holds 100 sequences.
Record a sequence in TRAX mode (up to 16 tracks, varied lengths) to present 4 at a time to the Gate/CV jacks + MIDI out channels + percussion
Record Layers of MIDI from a keyboard or controller on any channel, up to 15 Layers. Save with Sequence.
Record panel/CV/MIDI controlled automations of sequence modifiers (transpose, note tranforms, scale quants, jumps & loops)
Records and recognizes MIDI MPE zones + CV out all 5 expressions
MIDI:
Remote control Transpose, Jumps to bars or markers
MIDI merge to add controller changes to synth(s) being sequenced, or record layers
MIDI control CC outputs and pitch bend CV's + MIDI output
MIDI output all 16 channels
PLAY:
Sequencer Mode has 4 Sequencer MIDI channel to Gate/CV Modes, up to 8 Loop markers
Drums Mode for 12 drum triggers, up to 8 loop markers
TRAX mode with 4 mute/solo/channel tracks of any length. Up to 8 loop markers per track
Layering live MIDI over loops or entire sequence (notes or controls)
Note transforms: Transpose, mirror, scale proximity quant, probability. Swing, pitch bend, Glide/Gliss
Assign CC-CV outputs to any MIDI CC/Function recorded in sequence
CONTROL:
MIDI Remote - Transpose via notes, change Loops, Pitch Bend all 1V/Oct CV's
MIDI Thru - takeover control of synth through the Sequarallel
Up to 3 CV inputs configurable to control almost anything in the Sequarallel or any MIDI control
MIDI input doubles as a sequence start/reset jack
Clock out doubles as an extra CV input
CLOCK:
Clock sequence play via clock input, MIDI clock, self BPM setting
Clock live Layer recording with clock in or MIDI from source
Arm for play on 1st clock, reset input, or MIDI transport message
Input Clock divider up to /96
Output (from MIDI) clock PPQN div/mult. /96 to x96
Self clock BPM
CV I/O:
Bipolar -5V to +5V, or 0 to 10V in 10V mode
All CC outputs configurable to MIDI CC's, Pitch Bend break-out, aftertouch, MPE unified
CC5, CC6, and ClockOut can be CV or trigger inputs
CV outs have individual Fine Tune and quick global master tune +/- 100 cents
DISPLAY:
Left side shows Notes/Octaves/MIDI# to CV's
Left side shows 3 x 4 grid when in Drum trigger mode
Right side has scroll-down on screen buttons (quick-boxes) to quickly change a parameter
Most quick-boxes can be held on to open a list or settings for it.
SAVE/LOAD:
Up to 100 MIDI sequences can be saved along with markers/settings for that sequence
Several hours of record time can be stored.
Layers recorded onto a sequence can be saved and load as Layers to control.
Global settings loaded on power-up or reset. Saved by the user (not annoying auto-saves!)
Behind the Panel:
Headers for future expansion
Link Header (standard MIDI I/O, 4 pins) for our other modules or DIY patch
Select Bus on PSU header (master & slave capable)
Availability: Sometime over fall
Price: Around $240
sutekina bipu-on
Yessssss, so excited for this, I will be ordering as soon as possible
Paranormal Patroler
w00t w00t w00t
tiger001
what about sync/collab/tandem with RiTM?
why VEL out if there are so many (more) MIDI parameters that are (more) interesting ? (poly - AT for one)
like your other modules range -5V -> +5 V ?
tuning in steps/intervals ? (like receive C-> output B)
any way to store sequences or to load/save (pre) recorded MIDI sequences ?
e.g. i have a MIDI sequencer that can output MIDI files type 0 or type 1, can i load/get these onto onboard storage?
this would pair excellent with ZAQUENCER
Sandrine
That would require a specific header as the RIT_M's link is in a proprietary format (not MIDI). I use the Sequarallel with the RIT_M with standard patching, mostly clock related. It's an interesting proposal worth having a look at though. What did you have in mind?
I am familiar with MPE and by all means this would work great with Channel Mode 1+1+1+1. Sequarallel can easily be responsive to the MPE poly message to switch in a selected function (I'm thinking pitch bend, but the others can be an option to bring to the velocity jacks) to the Velocity outputs. Never thought of it thanks for the suggestion!! It's in.
Not familiar with AT though...
I had 0-10V but removed it. -5 to 0V might not be as popular but at this stage it can be added as an option no problem. I used the module with the Reflex LiveLoop's RATE input and did consider it. So consider this a yes.
There is per CV & Master (quick box) fine tuning +/- 100 cents and in that same menu a Zero Volt Note offset. i.e. my SDS_VCO's are all set to "A" at zero volts, so the Sequarallels ZVnote is set to -33. (36-3) for those.
Yes, recorded sequences are stored in memory permanently, up to 100.
Parameters for the sequence(i.e. Loop/jump Markers, Channel Mode and channels, chord order type, clockDiv, original BPM, 14 character name) can be edited and saved with the sequence.
Type 0 or 1 are only differentiated by the channel handling, so that would be up to the sequencer you're recording from. Like a "raw" MIDI would fall to channel 1 because all of the data is sent as channel 1
That FW looks somewhat like a Beatstep pro, and yes I think it would
Thanks for posting these really useful ideas we're not worthy
tiger001
storing of sequences you'd play on the RIT_M ?
using the RIT_M as a sequence/loop selection tool?
using the RIT_M as a start/stop trigger?
i was not specifically referring to MPE, any MIDI control/breath/aftertouch/poly-aftertouch (each AKAI MPC can send poly at from it's pads) etc hold a lot of possibilities , whereas MIDI vel is just one value at the start of a note...
-5 ->0 might not be as popular but i think -5 -> +5 is more & more (all Rossums modules, Vermona, Flame, Percussa, ...)
i was fishing @ a way/possibility to access the onboard memory other than through the MIDI input
(more modules you can insert an SD card that you can easily remove ) if i'd recorded/have a lot of MIDI sequences on sort of storage, how to get them easy/fast onto the SEQUARALLEL - other than just recording it
-maybe a loaded memory with useful preset sequences when shipped would be an extra/added sales argument/value?-
thanks for you fiery, swift reply
btw, SEQUARALLEL sounds like a post-modern aquarel painter/painting
Sandrine
SD Card was going to be added but that would bring the module up to 10HP and bring deeper SD Card related menus and such into play, so it was dumped early in dev.
Recording the MIDI in is straight forward and duplicates exactly what is auditioned (it needs to be played anyway during composition, or I would hope so hihi ) so the final play would be into the Sequarallel
I have changed the panel a bit though as per your suggestions/ideas and am updating the "real" prototype (used in the videos) right now!
Notice the M in & Mout dedicated jacks and the CC's flow through to 6.
Everything else is the same.
Indeed I will include those into the CC# list (i.e. 0-127, then MPE stuff, and those) good idea!
tiger001
ok, no problemo
with what resolution is recorded?
if i play 192 ticks pqn, would that be recorded?
Sandrine
tiger001 wrote:
ok, no problemo
Yes, but:
Bar quantization (used for Jumps/Loops if there's no Loop markers in the sequence) would be halved as the ranges are 24/96 @60 to 240 BPM.
The resolution is the PPQN. I could probably add another parameter for the upper range of ppqn's too wink
..-maybe a loaded memory with useful preset sequences when shipped would be an extra/added sales argument/value?-
I do plan on adding some starter sequences for sure. I have one fun sequence I like to use called "popcorn" (yep that song!) I DL'ed somewhere years ago. It's fun to transpose it around by CV.
tiger001
or you could name cc(1)/Vel - > Val ?
bar Q for jumps / loops is super interesting, always.
48 ppqn was the reso for EMU SP12/1200 hiphop flagship
96 ppqn for the original AKAI MPC 60
nowadays a decent MIDI seq can output 192 ppqn which adds a whole level of live/human feel (contrary to all those comp-temporary (16) step sequencers the stores are flooded with)
3 (??) MIDI cc to CV outputs ?
clock out could be trig out for EOS/EOL ? (end of sequence, end of loop)
diffrentstrolks
Very excited for this, Sandy
My "select bus alert" went off; happy to see that protocol made it in! applause
sutekina bipu-on
I personally would heavily appreciate a selectable ppqn parameter. Some mpc's had this as a feature and it was a wonderful addition to change the feel of a sequence on the fly.
I'm starting to realize this could replace any other midi sequencer I have and that is giving me a few other thoughts. Please forgive me if i missed some details that were in the videos or elsewhere.
-can you use a trigger sequencer into the clock in? this is one of my bigger concerns, some gear happily take trigger sequencers to create a start/stop rhythm but some don't like when you output a trigger sequencer to its clock input. if this could be converted to midi & sent thru the midi out i'd be ecstatic.
-that also reminded me that my drum machine has a eurorack clock out. i often plug it into a clock divider as it's too fast by itself. can the clock input divide the signal coming in if necessary?
-would there be headers on the module to allow for use of a midi breakout module? (making a 5 pin din MIDI connection). if i decide to use this as a master sequencer i would become worried about clutter of 5 pin midi cable adapters coming off the front panel.
- I noticed the auto-rec mode. It looks like what i'm looking for, however is this only for panel based changes? Can you record in loop mode like with the RIT_M, it seems like you can use it like an old school midi sequencer where you play in real time over a loop?
-you can dump the stores sequences as sysex or something?
-is it capable of concurrently looping midi tracks of different lengths? (if i have a 4 bar drum loop and a 8 bar rhythm and a 32 bar melody for example all looping) - or is it not an issue because the sequarallel sees everything as 2 bars?
-is there a "performance mode" where you have a list of all your sequences / songs and can select the next one to play after the current one is finished?
-lastly - this might be a lot (too much?) to ask but what if one of cc5/cc6 could be switchable to cv input in software? my idea is using a separate cv sequencer i have to modulate the sequarallel while it's playing. I have a setup where one step sequencer on a very slow clock playing a note into another step sequencer which has a cv/transpose in connector. Then you could pick which track 1-4 you want to be affected by the transpose CV input. i think would be great for playing improv too...
my idea is really just stolen from here https://youtu.be/_lnve907PVs?t=88
Sandrine
I figure for the most part those CC 1-4 will be either control CC's or MPE (CC(AT)/note or pitch bend) or velocity. "Data" would also work but CC continues to 5 & 6 so looks nice ...
I have used 96 and yes there is a finer feel to it, especially when recording from piano etc.
Good idea. It can be either transpose input, Jump control, or channel mode selector, so that could just be another option in that list.
Yes I replaced the 3rd CC-CV with deedicated MIDI in. That took a lot of complexity away believe it or not. There is a way to make that input auto-detect a non-midi plug so could be a trigger input for something when not being a MIDI input I might implement (requires another optical isolator though to keep it 100% isolated as per MIDI protocol)
Sandrine
Ha ha! Yep! The hardware is in place, the implementation is another thing.
The thing I see for Sequence selection (outside of using the Matrix) is a SelectBus list of sequences you want to load... There may be more (like parameter control etc) but that's the most obvious...
Wow! Lots of questions, thanks!
Yes input Clock Div is there /1 to /16, /24, /32, /64, /96.
Behind that quick box is ppqn /1 to /8 to *2 to *16 and *24 for MIDI to Clock Out jack. The Clock:/x quick box is in one of the videos but I haven't shown it yet.
With the present clock algorithm varying clocks cause a "swing" which is oddly entertaining, but the old "nobody knows the future, but we all know the past" axiom is true here. The rate will be based on the last 2 clocks minimally, so a missing clock will only yield a slow-down after the expected clock time has passed.
This isn't a step sequencer in that respect, more of a sample player really, with events that happen between clocks.
yes, as above, the clockDiv can be set to whatever clock division.
There is a simple backplane header for MIDI I/O. This is primarily for interfacing with our other modules (or others) like the Reflex LiveLoop or the upcoming Accord Melisma.
These are configurable to act as MIDI splitter and merger to/from the front panel, Channel separation/isolation splitter, etc. so could also be a front panel mirror with these options. smile
Those two are totally different functions.
Yes Auto-Rec is "automation recorder" and record all panel changes over a set number of bars (up to 64) before switching to play the automation.
The ClockOut, when not being used with a MIDI clock input, becomes an analog input (hence the upward arrow) that can offset the transpose, select jumps around the sequence by markers or bars (if no markers), switch Channel Modes, or Chord Order. These are also recorded by AUTO-REC.
One quick box I removed was "OverDub" but that's being replaced with REC-LAYER eventually. when turned on, all incoming MIDI (notes, CC's, Program Changes, etc) will be layered onto the playing track whether looping or not. This was proposed by Paranormal Patroler with the idea that a track can be built up.
This layering is only temporary and can be removed selectively, but also can be saved permanently with the SAVE EDIT box.
The channel used is the channel the new tracks are recorded onto so it's a pretty powerful addition.
-you can dump the stored sequences as sysex or something?
On the Pedal 7 sequencer I designed and loosely based this design on I can do that. It's more of a backup dump scenario and works fine with MIDI-Ox software to save/load up the on-board memory, but it's god-awful slow. It would take almost 2 minutes to dump/load.
That said, I will probably still add it as it does add possibilities, especially for performing vs. experimenting canvasses.
I don't fully understand the latter part but no. That would require splitting tracks into arrangements and would become really complicated to use.
In your example, that would just be the sequence as arranged in DAW or being sent out by another piece of hardware.
Loop points are added to the sequence (either by special note in sequence or post recording from the panel) that Loop on/off and JumpTo will respond to, or just single bar loops if there are no markers.
Interestingly the Pedal 7 has this and I have been trying to resist the temptation of adding it here, but any more comments on that and it will be ha ha!
I personally like it because
a) It can queue up the next after a stop and wait for a Play arm, or change in clock, whatever
b) can be set for which sequences auto-load in order
c) can just play out all sequences (self clocked to original BPM if no clock)
At this point only the Clock Out jack, as mentioned above, and possibly the MIDI in trigger alternate are the only inputs (other than actual MIDI input) that can control the sequence. But never say never wink
The Clock jack can CV control the transpose. Right now it's under CLOCK:/xx box with transpose, Jump, ChanMode as options. I suppose an "ALL" or "CHAN:xx" could be an extra transpose option easy enough
2 easy ways to do what you are suggesting (I have already done it) is to either turn on REMOTE quick box and transpose all via MIDI (I use a keyboard) or just use a MIDI controller to send Pitch wheel data to specific channels that will change while playing the sequence.
Thanks for all of the questions, I enjoyed answering them all! I'm sure everyone is a bit more (or lot) informed about the Sequarallel now thumbs up
sutekina bipu-on
Thanks so much for your detailed replies, Sandy! I have a much better idea of how i can plan out having fun with this module thumbs up Also I am super excited because i think it can work as the long awaited and very much needed replacement for old style midi sequencers like the mmt8.
The length of time for a sequence backup scenario is not too concerning to me. I don't see myself using it often, just when i want to be absolutely sure if i ever have to re-initialize the module for whatever reason or accidentally delete something.
I also totally missed the arrow coming from the clock out connector, so that is awesome to hear. applause
I apologize for the confusion lol
I had the Elektron Octatrack in mind when i was asking this. You can assign each track a different length however when i was going through the videos of the Sequarallel again I noticed, at least for the 2nd test video, all the loops were 2 bars long. Hence me asking if the sequarallel sees everything as 2 bars. But now I think that may just be because your demo song was made up of 2 bar loops and I was thinking faster than I could type lol
It's cool even if the Sequarallel can't do that. I've never actually had / used a sequencer myself that has this feature. But i always thought it was cool.
I've never heard of the pedal 7 so dang. I really gotta check that out. But my favorite hardware sequencers all had this sort of mode and I use it exactly the ways you do. And so I would be so very grateful if i could bug you to work that in applause
So so so hype for this. There has been lots of desire for a MIDI sequencer that is a spiritual successor of old school sequencers which had a minimal interface. The fact that this is not only that, but it's in Euro format, is really exciting to me and I think when more people become aware of this module a lot of people will see it's what they've been waiting for. thumbs up
Sandrine
Update!
After experimenting with the new layout (MIDI in/out, 6 CC's) with the above thoughts in mind I have decided to add these panel changes:
MIDI in jack:
When used with standard TS patch becomes a Reset/trigger for Play/Stop. The thinking here is when used with MIDI, a MIDI Play/Stop and clock will control the module's sync etc. and Clock Out will have the clock for everything else.
When used with a trigger and constant clock, sequencing begins. Subsequent triggers will restart the sequence according to the present JumpTo setting. So if JumpTo is set (via CV or quick-box button) to 0 then the sequence will re-start from the beginning, if JumpTo is 1, then sequence will go to 1st marker (or bar) etc.
If the S button is pressed, then full Stop is armed for the next trigger.
Starting a sequence playing can still be hitting P button if there's no clock at the time, which will arm for the 1st clock pulse. If there is no clock at all it can be forced to start (under self clocking @ original BPM) by hitting P a second time.
CV 5 & 6 jacks:
After much deliberation I have decided to make both of these jacks bi-directional. I see the need for more simultaneous control. These inputs (CV) can be configured to select JumpTo points, transpose, CV ChannelMode, MIDI controls (modulation, PW, PC etc).
They can be set, along with most other parameters, per sequence. They will drive <40mA so not a disaster if patched against another output by accident.
MIDI Out:
If a regular T-S style plug is patched in, the MIDI out will send Loop Triggers instead. The advantages of this are obvious, to sync up other sequencers or step to select a different JumpTo or transposition or whatever else
Clock Out will still maintain it's I/O ability.
These I/O settings can be made and left as global default settings for all new sequences at which point they will be saved with the sequence, but can be edited afterwards. That's how it is now.
This will make the sequencer so much easier to sync and offer a lot more control over sequences! Not sure how to graphically represent this yet though he he
@ sutekina bipu-on
-on the multi-tracking, I can't really think of an easy way to present that to the interface (i.e. starting/stopping individual tracks) but switching channel modes not only select which channels go to the Gate/CV outputs, but also which channels are blocked, so in effect acts in a similar way to multi-tracking. For example (here I go!):
Channel Mode 1+1+1+1:
MIDI channels 1,2,3,4 but 1&2 are MIDI blocked
Channel Mode 3+1:
MIDI channels 1 and 2, but 1 is blocked
Channel Mode 2+2:
MIDI channels 1 & 2, but 2 is blocked
Channel Mode ALL4:
MIDI channel 3, but is blocked
So switching between these 4 would send over MIDI
1+1+1+1: all but MIDI channel 1&2
3+1: all but MIDI channel 1
2+2: all but MIDI channel 2
ALL4: all but MIDI channel 3
These 4 configurations could be expanded to block any of the 16 channels really, just a longer list to select from wink
tiger001
if i understand correctly, this plays 1 sequence at a time, with up to 16 MIDI channels simultanously
those 16 MIDI ch can be directed -more & less- to 4 full ch & 2 cc outs
1 MIDI ch goes to 1 ch/cc so there is a Bijection (relation) with the possibility to block/mute MIDI ch (why not merge MIDI ch to ch/cc ?)
but loops points etc are always per sequence, not per MIDI ch ?
if you replaced the third cc out with a dedicated MIDI in, please update the feature list
love the overdubbing possibilities, please add punch in/out (?)
what i found very neat in (old) MIDI sequencers was the possibility to add/cut/copy/randomize/move MIDI notes and/or values (cc etc) as percentages, not only as hard values or minus or pos
Sandrine
That's right. But I guess I need to be more clear on the Channels Modes.
1 channel can be fed to all 4 for chords, or 2 channels fed to 3 and 1, 2 and 2, or 4 channels individually.
In the channel selector<-->jack /mode, presently there is 1-16, so merging would add "global" or "all" so all channels have access to the jacks at once?
The CC's can be any channel, but if assigned to AT function then the channel is locked to the note's channel
For per channel notes (MPE) only CM 1+1+1+1 would be useful (assigned ch2+). MPE PW on the CC's would apply, but could be on the 1st jack's row but CC74 (cut) on the rest so single note keying would be bendable (to the CC jack) while others not. I wonder if some MPE controllers can send mod (CC1)?
Also right. I would love to split them up but how would one control multiple loops?
There would still need to be a way to turn each on/off, jump to markers etc. From the panel, OK, but via CV's one needs to select to channel, while the other the marker, then a trigger to make it happen...
Intriguing to say the least!
Yep, indeed it is now as shown, way better too. MIDI in can also be a trigger input for reset, start/stop if used with a T-S plug.
The overdubbing is in the works, and yes it can be left in record or turned on/off at will. I like the "build" capability of this. I also plan to provide access to layers on/off with a LAYER quick box, and CV control to toggle a layer on/off sequence-wide. I think this would be amazing for jumping around in a sequence and adding layers in loops without having to hit record, and have CV toggling them on/off.
Then layers can be saved if you want. So basically you could just have a percussion sequence with some loops, record whatever you want on top of it, then jump elsewhere, making a whole composition.
If the keyboard/controller has capability to switch channels easily, then multiple channels will be recorded.
Really? Are we talking DAW sequencers or...
There's chop, randomize and quantize in FL Studio + other stuff but that doesn't really make sense here.... without a large display he he
Switching around note orders randomly would be cool, as well as inversions, but again how to control? within a loop?
"NOTE EDIT" quick box--> INV:+2-->RANDOM-->REVERSE
OMG that looks good!!
You're an idea guy aren't you Dead Banana
tiger001
hey, i'm merely the declarant
select notes in a seq (maybe in a/the loop, or bar/beat markers), then inverse/reverse/mirror around an imaginary line (the middle to make it easy, could be any -'drawn'- line, horizontal or vertical) full/all, or 50%, or 25% etc
same with random, copy, move etc - even play
-what's important when editing is to keep the selection active, not 'deselecting' when the processing is done
-when all is done on 1 sequence but possibly 16 MIDI ch, it is important to be able to distinguish between MIDI/ch so that processing is selective, not global on all notes/MIDI (messages) in the sequence
-there are a lot of fun things you can do with (only) notes, or (only) MIDI cc, or (only) velocity/pressure
MIDI cc has everytime a MIDI channel tied with it, these are not global messages, but channel ones, like channel aftertouch etc
so i hope i understand you right : if i play MIDI CC 27 values 0-> 127 in a 2 bar sequence on channel 2, i can direct/play those through sequarellel ch 2, or 5 or 6, to my choosing and that will output CV -5->+5V, or 0->10V, as chosen/setup/configurated
channel AT locked to ch output sounds logic
poly AT too - btw, this is a MIDI 1.1 protocol, not MPE
if you send MIDI cc1 over from a traditional instrument, it will influence the whole sound
if you send MIDI cc1 over from a MPE instrument, this can influence every tone/note apart
still, a merge with/between particular channels would be awesome (e.g. MIDI ch 1-3 play sequarellel ch 1, MIDI ch 4-6 output ch 2, MIDI ch 7-9 play ch 3, MIDI ch 10-13 play ch 4, MIDI ch 14-16 play ch(cc) 5)
-why give all MIDI ch access to all ch at once ? then all ch would output the same ? (unless you can select particular MIDI ch, or mute some per ch)
Sandrine
Ah OK! So that wouldn't follow musical rules of an kind, interesting. I had thought about inversions +/- and random but within perceived chord parameters within a single bar... Seems it might be a bit intense with the UI as it is, but always a possibilty.
On that note (ar ar) I am considering a bar-by-bar display of notes on any selected channel. That's always cool. Maybe could go from there...
This might still be of interest to some (myself included):
I had implemented a special MIDI record (overdub) that, when a keyboard is plugged into the MIDI in, would set all of the notes to the last notes played live based on their previous relationship with each other both pitch-wise and positionally of course, eg
An arp sequence of C2,E2,G3,E3,C4 with an EMaj at octave 2 would become E2, Ab2, B3, Ab3, E4.
But it was super hard to control! I may give it another try with Arp timing rules or some other algorithm...
If it worked right, this would be amazing. Then parameters such as inversion or random could be set.
Of course.
I was thinking, as per below, that perhaps rather than a single channel for the CC /AT value, have a range declaration i.e.
CC1:AT CH:02 TO CH:CH:05 so that range of channels would be present on jack CC1. In the Channel Modes List (under 1+1+1+1) channels could be set 2,3,4,5 for individual gates or just one jack CH:02 to CH:05
Yes, but the MPE option is there anyway
I'm still learning the MPE format, but wouldn't each channel be set to the same instrument for use with regular GM MIDI synth?
I understand that each note played is organized into which-ever order (that's the crux of the issues with bringing that to the panel) over separate channels, so accompanying CC's or AT/PW messages apply per note per channel. It's a cool concept, but for the panel jacks this polyphony would need to be limited to 4 if that's do-able with this MPE hardware...
Yes true, channel ranges would take care of that. SO I'll set it up that way.
My logic was that ALL channels would follow the CC1-4's setttings, but it's more logical to just also have ranges in ChanMode's.
for single channel operation settings would be like CV1:CH:01 TO CH:01
Good!
Sandrine
In this video, I create a simple sequence, record it in, then modify it with MIDI input, panel, and CV inputs.
The Sequarallel is slowly changing into the release version and this video marks some decent changes that make more sense:
+Velocity Jacks now assignable to CC, Velocity,AT, and MIDI MPE compatible
+Old CC1 jack is now "dedicated" MIDI input. (Korg TRS)
+MIDI input can also accept Sequence Reset trigger if normal T-S plug used
+CC's 5 & 6 are bidirectional configurable per sequence
+Added Clock Out arrow to show it is bi-directional for Analog controls as well
Time stamps:
New! 0:50
Composing Sequence (with loop markers) 2:10
Recording! 4:55
Play it! (looping, Jumping) 5:30
Transposing and Modifying Instrument via MIDI Inputs 6:45
Transposing with panel, then with MIDI Remote 8:15
Clock Out Jack, CC 5&6 jacks 9:50
AUTO-REC Automation recording 10:28
Bad Loops! 14:10
CV Controlling Jumps 15:53
More advanced features are also in the works but won't be explored until the new design (for the bi-dir CC5&6 mostly) is ready.
Manufactured PCB design is also being updated.
Sandrine
I have updated the original image at top of thread to the real prototype and made up this panel description for a one-shot look at the main features of the sequencer.
Sandrine
I have been thinking about this mirroring notes.. Are you familiar with a software that does this, I'd like to see an example of it as it sounds really interesting. Adding this to the CV input control list OMG!
A vertical mirror is pretty obvious but a horizontal line, would that quantize at all? Or just invert the notes above or below? i.e line is at A and there's a sequence with C E G, so that would mirror G Eb C
I also like the randomize, jumbling up the notes in their original positions but using only notes in the range. This would work as long as the range wasn't too big i.e. 1 bar might have two complimentary chords ( C & G) so they wouldn't musically conflict but 4 bars (C & G & F) might
Update:
I have added Portamento/ Glissando to CV outs (It always existed in the MIDI realm of course) so will respond to Portamento types and time/speed. This can also be controlled via one of the 3 CV inputs, so even a simple gate pulse will porta some notes while others not, a pretty nifty effect, especially if that (LFO) is out of sync.
There will be a special quick box button for portamento/glissando and a parameter for it in Channel Mode List.(To the CV's yes/no/port/gliss/legato)
While it seems OK with my MIDI synths, there is no standard (it seems) for portamento timing so leaving this in might be risky biscuits...
Not sure if this is a good idea as feedback has been dismally minimal (of course my circles think it's a good idea!) it's almost required really so the CV's track with/as the MIDI or just to be able to porta/gliss CV notes
tiger001
this was software i used around 1990, i am thinking goldwave (canadian as it turns out!) , but obviously they do audio manipulation/recording but maybe they have an old (MIDI only) version of the soft i used during the 9T (or maybe they incorporated their nifty efx into the contemporary versions)
-i am also inquiring this question with other soft makers
that would not quantize, just invert to G E C ? or mirror to G eb C - just the notes/bars you selected of course (if possible), with a horizontal ruler 'around' a base note?
randomization in ranges (of course) in percentages? (like 25% random, 50 %, ...) i wouldn't worry too much about musical conflict, 90% of eurorack music sounds wrong anyway, that is much of intention (or not) / attraction
Sandrine wrote:
Update:
OMG, you're the blitz!!!
you could apply a (clocked?) timing, take a look at the famous glide in the roland TB303 (exponential, constant time) other possibilities are
fixed time or linear or exponential
on my roland TB03 glide is handled/initiated by MIDI cc messages but i think the use cases you describe above will sound great
Sandrine
Ah OK, that's pretty interesting too! Now I'll have to mess with it.
Of course the randomness would have a "probability" setting, but I think the re-use of existing notes should be an option.
I was doing a fast transpose series on Gun's n Roses' "Sweet child of mine" this morning in the Sequarallel and it becomes unrecognizable in some places, while others you can still hear the original, but the key shifts are still musical so it sounds good
Portamento is being a challenge in that do the CV's follow MIDI portamento request on a channel that is assigned to the CV's or not. Setting a portamento on the CV's is easy enough regardless of what the sequence is doing, but I think that shouldn't affect the MIDI output. That can be changed on the fly via a MIDI input anyway.
Yes there's parameters behind portamento like Porta or Glissando? Linear or curved (I remember that now thanks!) , start note CC, (forgot that one) rate/time, direction. That will probably be behind the quick-box (hold encoder on it to enter/exit)
Clocked portamento?
That's an interesting idea too! If was set to complete a run (gliss) in 1/8 then notes happening faster wouldn't get the full porta or wouldn't get played before another note. That's where tuning comes in, but if it was settable as timing 1/8, 1/16 etc then you'd be sure it would.
Update!
I have expanded the memory by 16X so will hold a lot more complex sequences. If max MIDI rate (~1 event/mS) was recorded, it would record for 94 minutes.
AT:
There will be AT support.
MPE:
There will be MPE support (Strike/AT/Glide/Slide/Lift).
I'm still trying to find out which RPN's are used to signal MPE mode. I know "old" hardware won't respond descriptions of the master channel and know to set PC's over on all following channels in another RPN described range.
The end game, besides the Sequarallel properly handling MPE to it's CV outs, would be conversion to set up "regular" synths etc. to work immediately with MPE (if this is needed at all?)
If anyone has a MPE keyboard or Linstrument with MPE could you please record some MIDI off it and send it over? Nobody near me has MPE yet razz
Page 1 of 3
