iProgram card?? - difference between mini and micro usb
bcomnes
Post by bcomnes » Tue Sep 17, 2019 3:59 pm
The iProgram card manual refers to using the mini USB port for non-WiFi access to the card, and although it shows the micro USB port it makes no mention of its use?
Is there a difference,? does it matter in hooking my iPad up to the card?
And since I'm writing what's that black socket above the network status LEDs for??
Finally, other than shorting 2 pins during a firmware upgrade, what's the purpose of the ICSP header
Thanks in advance to anyone who can enlighten me....
Too Loud?
Too Bad
meatcliff
Post by meatcliff » Tue Sep 17, 2019 9:17 pm
I can answer one of those... ICSP = In Circuit Serial Programming.
In most cases there's no end-user functionality, but this is how they'd program the firmware at the factory. If you look around you'll probably find a 6 pin ICSP header or footprint somewhere on almost anything with a microcontroller.
Drillionaire
Post by Drillionaire » Wed Sep 18, 2019 11:04 am
The Micro USB is only for updating the firmware on the WiFi chipset.
