ES-9 vs ES-8
DavidB
ES-9 vs ES-8
Post by DavidB » Tue Sep 17, 2019 8:06 pm
I've been considering an ES-8 for integration with Ableton, VCV, etc. The ES-9 seems like it adds more inputs/outputs (potentially avoiding the need for expansion modules), adds headphone and monitor out jacks, and uses USB-C. Seems like that would justify the additional $$ depending on use case/existing modules, etc., but is there any additional functionality I'm missing? Does USB-C improve the functionality meaningfully vs. USB-B (both look to be using 2.0)? Thanks.
Post by os » Wed Sep 18, 2019 3:00 am
The USB connection is just a different socket. It has no bearing on the functionality.
The ES-9 has
- more inputs
- balanced main outs & a headphone out
- a built-in mixer
- MIDI (via a breakout)
The ES-8 has ADAT, and is arguably more flexible if you're wanting to integrate it with an existing interface, but then there's also the ES-3/6 in that case.
bhenry1790
Re: ES-9 vs ES-8
Post by bhenry1790 » Wed Sep 18, 2019 10:41 am
I'm considering both too and the ES-9 looks amazing, but maybe ES-8 is better (for my needs) due to expansion with ES-3 / ES-6? My goal is to have a bunch of computer controlled modulation OUT of Ableton to my small modular. Inputs on the ES-9 are nice, but I would mainly use for audio (hardly ever CV)
I couldn't find anything on the Expert Sleepers site or ES-9 manual that addresses expansion with ES-3 / ES-6
Copied from Expert Sleepers site on ES-9:
For even more outputs (up to 48 more), the ES-9 can be expanded with the ES-5*. It also has a pair of S/PDIF sockets for connecting other digital audio gear.
The ES-9 also provides a pair of MIDI sockets (via a breakout).
* The ES-9 has a dedicated pair of audio channels for the ES-5. Unlike the ES-3 or ES-8, you don't lose audio outputs when using the ES-5.
I'm not sure how Ableton handles the special output requirements of the ES-5.
Unlike the ES-3 itself, the ES-5 requires particular software in order to generate meaningful output signals. Currently, the only such software is the 'ES-5 Controller' plug-in, part of Expert Sleepers Silent Way, and our Max/MSP external (see below).
Copied from Expert Sleepers site on ES-8 can be expanded to 16 out with ES-3 + 10 in with ES-6:
The ES-8 also has ADAT inputs & outputs. This could be used for example to expand the I/O count via an Expert Sleepers ES-3 and/or ES-6, or to connect a traditional audio interface to add, say, mic preamps or 1/4" line outputs (for example with the Behringer ADA8200).
EDIT: I think the ES9 could be a total game changer because of the ease routing CV/Audio to/from modular/computer. Eager to see the demos and uses
Post by os » Wed Sep 18, 2019 10:45 am
You can't. It doesn't have ADAT connections.
I'm not sure how Ableton handles the special output requirements.
It handles them fine.
If you're going with the ES-8, how are you connecting your speakers and/or headphones?
bhenry1790
Post by bhenry1790 » Wed Sep 18, 2019 11:40 am
os wrote:If you're going with the ES-8, how are you connecting your speakers and/or headphones?
Oh gotcha... Audio FROM the computer I hadn't considered. Ableton can only do 1 audio interface for output.
So looks like ES-9 or ES-3+ADAT interface are actually best options for me.
phutureboy
Post by phutureboy » Wed Sep 18, 2019 3:19 pm
sorry for my ignorance but how is a S/PDIF input (TOSlink) different from an ADAT input ? The plugs look the same but the ADAT allows 8 digital channels when S/PDIF (TOSlink) is only 1 ?
FS: EMS Analyse Filterbank B1-II | EMS AKS | RSF Expander I & II | PEARL Syncussion SY-1 | KORG MS-20 | KORG SQ-10
Post by os » Thu Sep 19, 2019 2:34 am
S/PDIF is stereo, but works natively at all sample rates (whereas ADAT only goes up to 48kHz).
ronnieb
Post by ronnieb » Tue Oct 22, 2019 4:22 pm
Sorry to hijack the thread but feel like it's topic related.
Can the ESX-8CV mk2 expand the ES-9 or is it only compatible with the ES-8?
Amazing work btw, thank you
:guinness:
philip_morison
Post by philip_morison » Tue Oct 22, 2019 5:36 pm
If you connect the es-5 to to es-9 I assume you can connect the esx-8md to utilize the 8 midi outputs.
Post by os » Wed Oct 23, 2019 2:19 am
The ES-9 can be expanded with the ES-5. From there you can add any of the ESX expanders.
pashacamera
ES-9 standalone mode
Post by pashacamera » Wed Oct 23, 2019 10:19 am
Hi! Got a question about standalone mode before purchasing ES-9. As I can understand, it works like a mixer when there is no laptop connected? So can I use all the 14 inputs and it will mix them to main output and headphones? Also if I use any stereo devices, is it possible to pair inputs to make them work in stereo mode? Thank you
Post by os » Wed Oct 23, 2019 11:01 am
In the current firmware only 8 inputs can be mixed internally. That may change.
Inputs can work as stereo pairs.
ronnieb
Post by ronnieb » Mon Oct 28, 2019 4:47 pm
Everywhere seems to be waiting on stock of the es-9, musicstore.de now has an eta of 12.12. Is that a best-case or worst-case scenario?
I'm suuuper excited/desperate to get my hands on one. I've been scouring the interwebs so long for details, I thought I should just see if you have any insight?
Post by os » Tue Oct 29, 2019 3:31 am
There were in stock; they sold out.
We're expecting them again at the end of November. You can reserve one here:
https://www.signalsounds.com/expert-sle ... ace-module
ronnieb
Post by ronnieb » Tue Oct 29, 2019 6:34 pm
One popped back in stock and I managed to snag it :yay:
Cheers to the beginning of the end :guinness:
Wubz
Post by Wubz » Fri Dec 06, 2019 5:37 pm
Hi, I'm hoping I can get some advice from you lovely people.
I have a clarett 8pre thunderbolt interface plugged into my mac mini 2018. I've been looking to get more audio inputs for my gear. This ES-9 has peaked my interest. I understand I could use it and the clarett 8pre at the same time as aggregate devices with my Mac. I've never actually tried this before) Would I be better to get an ES-8 and plug it into my clarett 8 pre via the ADAT connections, or get the ES-9 and use it in tandem with my carett 8 pre? I would be using it with Ableton predominantly.
Post by os » Sat Dec 07, 2019 4:42 am
You would be better using an ES-3 (and possibly ES-6) over ADAT with the Focusrite.
Unless you usually work at 96kHz, in which case it's not so clear cut.
Wubz
Post by Wubz » Sat Dec 07, 2019 2:16 pm
os wrote:You would be better using an ES-3 (and possibly ES-6) over ADAT with the Focusrite.
Thanks for the advice. I'm looking to get audio from my modular TO my computer. I thought the ES3 sends signals the other direction?
Wubz
Post by Wubz » Sat Dec 07, 2019 2:20 pm
Is the ES8 not going to perform well as an aggregated device with my clarett 8pre?
Post by os » Sun Dec 08, 2019 4:55 am
Yes, hence my mention of the ES-6.
It should. It's just more expensive and using an aggregate adds complexity.
komyta
Re: ES-9 vs ES-8
Post by komyta » Tue Jan 07, 2020 1:36 am
Hello,
I'd like to give a try to these very interesting modules.
Basically my needs are as follows :
- 6 channels of CV from Eurorack to Ableton Live (to control a few Reaktor Blocks)
- 8 channels of audio from Ableton Live to external mixing desk
I wonder if I'd be better with an ES-9 (all-in-one solution) or an ES-8 + ES-6 combo (smaller footprint, lower current draw).
Could there be any difference between these two solutions in terms of latency ?
Re: ES-9 vs ES-8
Post by os » Tue Jan 07, 2020 4:05 am
If you don't need the ES-9's 1/4" outputs you may as well stick with the ES-8.
komyta
Re: ES-9 vs ES-8
Post by komyta » Tue Jan 07, 2020 5:04 am
Thank you for your quick reply.
As you made no comment about latency, I guess there is no latency difference between these two solutions ( ES-9 or an ES-8 + ES-6 combo).
(I'm especially concerned about the latency of external CV -> ES-8 -> Ableton Live.)
Re: ES-9 vs ES-8
Post by os » Tue Jan 07, 2020 5:07 am
No. They use the same drivers.
komyta
Re: ES-9 vs ES-8
Post by komyta » Tue Jan 07, 2020 5:13 am
All right, thank you Os.
If the latency is acceptable for my needs, this system will be a game changer for me !
I'll report about my user experience in a few days.
Return to “Expert Sleepers”
