Korg Mono/Poly Key Assigner calibration
fracinfrucer
Post by fracinfrucer » Wed Sep 18, 2019 10:34 am
Hello folks. I have scoured the internet and can't find the answer to my question. In the calibration procedure in the service manual, after calibrating the power supply, you calibrate the key assigner to 1 volt per octave. It says to "Short the TUNE POINT." I am not sure what the tune point is that it is referring to. Can someone explain this to me? My Mono/Poly is off from octave to octave and I haven't been able to find "tune point" anywhere else in the service manual.
wally01
Post by wally01 » Wed Sep 18, 2019 11:14 am
If you have the service manual there is a tune switch indicated on the schematic on page 9 of the manual. It is right beside the 8049 micro.
The switch is physically located in the vicinity of the mid rage adjustment pot. (page 15 of the service manual). The switch should be open under normal conditions and then shorted when calibrating. I'm not familiar with the Monopoly but i hope this helps.
Cheers.
Pat
fracinfrucer
Post by fracinfrucer » Wed Sep 18, 2019 12:58 pm
Yes, I see the switch there now! Thank you so much for taking the time! :hail:
wally01
Post by wally01 » Wed Sep 18, 2019 6:03 pm
You're welcome!
Good luck with the calibration.
Pat
