Slider Pots / Optimal Front Panel Slot Dimensions
orchestron
Post by orchestron » Thu Sep 19, 2019 1:28 am
Hi,
I’m working on a DIY project and would like to incorporate slider pots. I was looking at the Alpha 30mm travel sliders (RA3043F-20), but would like to know if anyone here has other suggestions for good quality ones? See below for a link:
https://www.mouser.com/datasheet/2/13/A ... 522330.pdf
Second, could someone please advise on the optimal front panel slot length and width for these sliders, assuming a total component length of 45mm, a travel length of 30mm, and a lever width of 6.6mm?
Many thanks in advance.
cackland
Post by cackland » Thu Sep 19, 2019 4:21 am
The data sheet should give you the dimensions for each slider you are referencing. I always use the dimensions + 0.5mm. They are generally very accurate dimensions so I wouldn't go much larger than this.
Alps and Bourns are great quality sliders. Prefer Alps though (personal pref)
