Select Bus Problems
Moderators: Kent, os
javes777
Select Bus Problems
Post by javes777 » Mon Sep 23, 2019 1:49 am
Hi Os,
I have 8 distings hooked up to your select bus module and sending CC for parameter changes to them using Lemur and I'm saving and recalling using program changes in the usual way.
However, my Lemur instance is also sending CC through the select bus module (the out is just a copy of the in on the select bus module??) into the midi breakout for the FH-2.
The problem I have is that if too much midi data (not on any CC the distings actually use) is received by the distings, they all kinda crash and stop responding to midi at all. They seem to work fine in themselves. I have to reboot them all to get the midi working again.
Pitchbend data I have running from an LFO on Lemur seems to cause the issue for example.
The distings are set to midi channels 1 to 8 for the CC parameter changes, but the select bus program change is set to channel 1 which all the distings pickup anyway. Midi thru on the distings is off.
I don't think Lemur is at fault, as the midi messages are still being received fine on the FH2 - which is still responding and showing the midi history. (midi history has been a great help getting my template this far!)
Please could you take a look into this for me?
Post by os » Mon Sep 23, 2019 2:54 am
Does it make any difference which algorithms the distings are running?
javes777
Post by javes777 » Mon Sep 23, 2019 3:30 am
Not that I have noticed.
Post by os » Wed Sep 25, 2019 3:21 am
Does changing algorithm (& back) restore MIDI functionality?
javes777
Post by javes777 » Wed Sep 25, 2019 8:26 am
Hi os.
I’ll check tonight.
I’ve also noticed that when a save select bus message is sent, z is returned back to the knob value even though I’m sending z cc.
Is there any chance the z cc could be saved with the select bus, or at least the z value staying at the cc after the save?
javes777
Post by javes777 » Thu Sep 26, 2019 3:18 am
Hi Os,
Changing the algorithm does restore MIDI - for that Disting. :)
Ta
Post by os » Thu Sep 26, 2019 3:45 am
OK, so I think what we're looking at is the MIDI receiver overflowing when the disting is busy doing something that takes a long time - e.g. a preset save, or a SD card operation. Changing algorithm resets that.
Any idea what that long operation might be, in your case?
javes777
Post by javes777 » Thu Sep 26, 2019 4:52 am
It is when saving a recalling presets via program change.
Post by os » Thu Sep 26, 2019 5:52 am
Please could you try this beta and see if it's improved?
image.hex.zip
(211.73 KiB) Downloaded 2 times
javes777
Post by javes777 » Thu Sep 26, 2019 6:36 am
Thanks very much Os. I’ll test tonight.
Did you see the above note above saving z?
Ta
Post by os » Thu Sep 26, 2019 6:40 am
I did.
javes777
Post by javes777 » Fri Sep 27, 2019 3:29 am
Hi Os,
Unfortunately, the beta did not work.
I send pitch bend data by an LFO from Lemur and the select algorithm function works a couple of times then freezes. Same for using both program change and CC to select the algorithm.
Post by os » Fri Sep 27, 2019 5:11 am
Please let me know which specific algorithms you're switching between via MIDI and I'll see if I can reproduce your exact setup.
javes777
Post by javes777 » Fri Sep 27, 2019 5:29 am
It is any algorithm. But I was going between b7 and a1.
Post by os » Fri Sep 27, 2019 5:34 am
There's actually a chance that B7 is a special case. Could you try going between A1 & A2, say?
javes777
Post by javes777 » Fri Sep 27, 2019 6:06 am
I’ll try tonight Os.
javes777
Post by javes777 » Sat Sep 28, 2019 4:18 am
Hi Os,
Moving between A1, A2 and A4 works. But pretty much everything else causes it to freeze.
Post by os » Mon Sep 30, 2019 3:13 am
Could you please try the attached with B7?
image.hex.zip
(212.16 KiB) Downloaded 2 times
javes777
Post by javes777 » Mon Sep 30, 2019 11:10 am
Hi Os,
B7 works now, but B3 doesn't as well as lots of others.
Ta
Post by os » Tue Oct 01, 2019 4:23 am
Cool. Could you try this one?
image.hex.zip
(212.2 KiB) Downloaded 1 time
javes777
Post by javes777 » Tue Oct 01, 2019 11:53 pm
Hi Os,
B3 now works, but it is still freezing on the Env algos, G7, H5, most of the I algos. I stopped checking after that..
Ta
javes777
Post by javes777 » Fri Oct 04, 2019 3:13 am
Hi os.
Any more updates for me to test?
Post by os » Mon Oct 07, 2019 3:42 am
This should sort out the envelopes and Euclideans.
image.hex.zip
(212.38 KiB) Not downloaded yet
javes777
Post by javes777 » Mon Oct 07, 2019 12:29 pm
Thanks for the update Os.
I've not been able to try it yet, but there are further problems with the SB..
Saving SB 3 or 4 times seems to then crash the SB and all my disting memories of the saves are gone. It starts to work again after a few more saves, but what I had is still gone.
Can you confirm at your side?
Ta
javes777
Post by javes777 » Mon Oct 07, 2019 11:35 pm
javes777 wrote:Thanks for the update Os.
Ta
Hi Os,
The problem actually occurs on the 6th save from powering up the distings.
All I'm doing is changing one parameter and saving with the program changes. Nothing fancy or complicated happening with the midi.
This happens on lots of algorithms.
Changing algo or rebooting the distings does not bring back the saves.
Once this is fixed, I'll be able to share the Lemur template as it is finished. :)
Return to “Expert Sleepers”
