CGS 1973 VCF and Triple Waveshaper questions
pftjschute
Post by pftjschute » Thu Sep 26, 2019 1:22 pm
Getting started on my first Serge build and I ran into a little confusion on two things.
1973 VCF (CGS77):
- The component kit from Elby contains 2 100nf polyester caps and 3 ceramic caps but I'm confused which caps need to go where.
- I put the polyester caps where I think they should go (circled in yellow). In the picture on the CGS build documentation page they reach all the way across their rectangles.
Triple Waveshaper:
- All of the diodes on the board should be 1n4148, but the kit also included a single 4v7 diode and I don't know where it's supposed to go
*Please let me know if there would be a more appropriate thread to post on instead of creating a new thread.*
djs
Re: CGS 1973 VCF and Triple Waveshaper questions
Post by djs » Thu Sep 26, 2019 2:16 pm
pftjschute wrote:. In the picture on the CGS build documentation page they reach all the way across their rectangles.
This is to accommodate different part sizes. If you look at the traces on the board, the holes on each end should be all linked to each other.
"Noise is what the Earth is made of" - David Bowie
djs
Post by djs » Thu Sep 26, 2019 2:20 pm
pftjschute wrote:- All of the diodes on the board should be 1n4148, but the kit also included a single 4v7 diode and I don't know where it's supposed to go
Per the bom here:
https://www.elby-designs.com/webtek/cgs ... -cgs77.pdf
There isn't a 4V7 diode (I'm assuming it's a zener) needed for this build. When I built mine, I don't remember one on there either. My guess is you just got a bonus part.
Are you short a 1N4148 somewhere?
Le Thon
Post by Le Thon » Sat Sep 28, 2019 1:17 am
Yes, Poly caps in Yellow circle, Ceramic in red circle.
No 4v7 diode in TWS, only 12x 1N4148.
*Better to ask that on the Music Tech DIY sub-forum, i think.
pftjschute
Post by pftjschute » Sun Sep 29, 2019 10:47 pm
thank you, will put this in that sub next time
