ES-5 Clocks
Moderators: Kent, os
dlarseninclusive
ES-5 Clocks
Post by dlarseninclusive » Sat Sep 28, 2019 9:57 pm
Is it possible to send out more than one clock signal on an ES-5 from an ES-8?
I don't understand the pattern at all.
Output 1 Makes sense. Output 1 is the ES-5, and all 8 outputs are sending the same clock signal.
Gates 1/1 - 1/8 have no pattern that makes sense, short of being some division of 256 from the ES-5 Controller output.
Ranging from no output, to whatever its doing by 1/8. Is this the expected behavior? How does it work? Thanks!
dlarseninclusive
Post by dlarseninclusive » Sun Sep 29, 2019 1:03 am
Ok, this "Works" according to the pattern outlined above, I get two signals.
1/5 overlapping 1/3 is not a problem in this case. Can't get outputs 1 and 2 to work like this. **Edit** ok, 1 and 2 work using gates 1/3 and 1/4.
Is it possible to get all 8 to work, like Pam's new workout?
Image[/img]
Post by os » Sun Sep 29, 2019 2:56 am
Looks like the plug-in is being affected by a non-0dB gain, e.g. the track fader. Or you have it on a mono track instead of a stereo one.
Can we see more of the DAW setup, rather than just the plug-in window?
Also, is the ES-8 the only audio interface involved here?
dlarseninclusive
Post by dlarseninclusive » Sun Sep 29, 2019 11:06 am
Sure thing,
The ES-8 is the only interface as far as Bitwig is concerned, it pipes into Voicemeeter, and is output to speakers via a second interface.
This describes the master out routing in Bitwig. The 'ES-5 Clock ' track is operating on a stereo pair 7 & 8. The track fader is in its default position
This is what it looks like when I hit play in transport.
dlarseninclusive
Post by dlarseninclusive » Sun Sep 29, 2019 1:07 pm
One thing I will add, (that seems like a separate thread, but clock related). Is the ES-8 defaults to ADAT clock in the control panel and that results in a periodic feedback loop, that sounds like a filter sweep. Changing that to internal clock makes that go away. I have to set that more or less every time I restart the computer.
Post by os » Mon Sep 30, 2019 2:09 am
Bitwig track faders don't default to 0dB. Set it to 0dB and it should start working as expected.
dlarseninclusive
Post by dlarseninclusive » Mon Sep 30, 2019 9:41 am
So far so good, that looks like it works. I'll keep you posted.
Return to “Expert Sleepers”
