I’m looking to buy cables to link ALM S.B.G to Eventide H9
Tomorrow Sounds Good
Post by Tomorrow Sounds Good » Tue Oct 08, 2019 2:22 pm
I know what they should look like but don’t know a name to search for , any help greatly appreciated! :sb:
(It’s been a long day at work)
mgscheue
Post by mgscheue » Tue Oct 08, 2019 2:56 pm
For CV? A floating ring cable.
deftinwulf
Post by deftinwulf » Tue Oct 08, 2019 3:33 pm
Sounds like you're just asking for 3.5mm (1/8") to 6.35mm (1/4") cables?
You'll want TS to TS cables in most cases.
CONTROL sells them if you're in the US, as do many other shops.
https://www.ctrl-mod.com/collections/ca ... able-black
Or you can buy the same thing from HOSA just about anywhere.
Post by Tomorrow Sounds Good » Tue Oct 08, 2019 4:11 pm
Thanks :tu:
cptnal
Post by cptnal » Wed Oct 09, 2019 2:50 am
You should have got a floating ring cable included. Was the SBG second-hand by any chance?
Is it finished?
Latest Tune:
Sounds: SoundCloud , Freesound
Racks: Big Case, Skiff, Waveform Laboratory, Funboat
deftinwulf
Post by deftinwulf » Wed Oct 09, 2019 9:57 am
Just commenting again to add: two people have now recommended "floating ring cables", which after googling I realize is what I think of as TS to TRS cables.
If these are required, and they very well may be, I did not know it. You may want to hold off buying TS to TS cables as I may have told you to get the wrong thing.
You might be needing one like this instead: https://www.thonk.co.uk/shop/floating-ring-cable-14m/
Hope this helps. :party:
cptnal
Post by cptnal » Wed Oct 09, 2019 10:05 am
Mine was more a quote from the manual than a recommendation. :mrgreen:
Is it finished?
Latest Tune:
mgscheue
Post by mgscheue » Wed Oct 09, 2019 10:08 am
TS to TS is right for audio so your answer is fine for that. I was just assuming the OP was asking about the cable for CV into the expression input, and that does require a floating ring cable. cptnal is right, though: the module comes with a floating ring cable but maybe he got it used or was asking about audio cables.
noeticsound
Post by noeticsound » Wed Oct 09, 2019 10:18 am
deftinwulf wrote:Just commenting again to add: two people have now recommended "floating ring cables", which after googling I realize is what I think of as TS to TRS cables.
I believe the including floating ring cable is for integrating an expression pedal into the SBG's lower module (expression pedal to CV). For connecting a pedal like the H9, the cables should be 1/4" TS to 3.5mm TS, one for send and one for receive.
cptnal
Post by cptnal » Wed Oct 09, 2019 10:25 am
Yeah, the included floating ring cable is for CV. You have to fend for yourself for audio cables, but those are plain 3.5mm to 1/4"
Is it finished?
Latest Tune:
