disting k8 stereo clockable delay not clockable?
_lampshade_
Post by _lampshade_ » Wed Oct 09, 2019 12:06 am
hi little bug report i think, I'm unable to get the clock in on z working on the K8 stereo clockable delay algorithm. the knob works as tap tempo, but sending a clock in doesnt seem to do anything.
love the distings
Post by os » Wed Oct 09, 2019 2:50 am
Works for me. Perhaps you've just got the Z knob turned away from zero, adding an offset to the clock?
_lampshade_
Post by _lampshade_ » Wed Oct 09, 2019 1:25 pm
oops that did the trick thanks
moonscience
Re: disting k8 stereo clockable delay not clockable?
Post by moonscience » Sat Feb 08, 2020 10:28 am
More K8 questions:
Is there a quick way to clear the buffer (sometimes just rotating the z-knob seems to MOSTLY wipe out the buffer)?
I'm really interested in using the disting as a stereo looper, and I assume the K8 function is the best way to go about doing this. So far a delay time of 0 (not sure what negative delay time is) and a feedback of 32 mostly works. Right now I've been having the best luck by just pressing the tap tempo at the start and end of a sequence, and assume (having watched the video) that you could do this to make extremely long loops if your patient enough for that long tap--or just use an extremely slow clock?
Really just looking for clarification. Work has been super busy and hardly had time to touch my synths.
Post by os » Sat Feb 08, 2020 12:07 pm
The disting could really do with a dedicated looper mode.
The delay have the 'Delay time multiplier' parameter so you can tap 1/16th of the loop time, if waiting for the whole loop would take ages.
moonscience
Post by moonscience » Sat Feb 08, 2020 10:50 pm
It does seem like K8 is very close to a dedicated looper. If the disting had an SD looper would time stretching/pitch shifting be possible?
Return to “Expert Sleepers”
