DIY Hydrophone
Author DIY Hydrophone
Joix
For a special art performance Go with the flow at Port25 during the Nachtwandel im Jungbusch I had the mission to make sounds out of a water installation, so I researched the internet for proper building instructions to make a hydrophone by myself, because they are quite expensive and rare. I found an excellent building instructions shared on a meeting of Acoustical Society of America.
Check out more here: http://www.joix.de/hydrophone
lud
Interesting... Thanks for sharing!
BLX
IS there any recording of your finished piece? I've often wondered how good a hydrophone would be at messing with sounds?
Thanks for posting
Joix
Here is a new video with triangel: https://www.facebook.com/joix.music/videos/820676098389994/
I will be part at the art performance "go with the flow" this weekend and will make some audio records there
Graham Hinton
It doesn't mess with sounds, it enables you to record sounds where you can't use a normal microphone.
Here's one I built for recording Cary Grace's version of '1983... (A Mermaid I Should Turn To Be)' :
It's just a piezo element inside a waterproof can connected like a balanced mic. It took quite a bit of waterproofing with sealant.
All the "underwater" sounds on the track were recorded with this, mostly in a bathtub, and messing comprised lowering two octaves on tape or mixing with "overwater" sounds from another microphone. Lowering a vibrating metal part into the water and recording the pitch change in and out of the water was one source of sound.
huffnPuff
So if DIY stands for Do It Yourself, I guess DYI stands for Do Yourself In?
Joix
Haha, thanks for telling this, fixed it wink
Joix
Here's a little audio record of the art performance with hydrophone sound installation:
[s]http://soundcloud.com/joix/quellwassertransport-port25[/s]
