Stasis Leak by Frequency Central
Jsharpphoto
Post by Jsharpphoto » Wed Oct 23, 2019 9:37 am
I’ve been sitting on this for a few weeks, but since it’s live on Facebook, I figured it was fair game for a thread.
This is a 1u wide Chorus/Delay/Reverb module.
Some important facts:
1. It will be available assembled or as DIY.
2. The reverb and chorus are the only effects that run stereo.
3. If you’re using the tap tempo or external clock, the time knob produces subdivisions or the clock source.
4. In chorus mode, time = rate, and density = depth
5. In delay mode, time = delay time, and density = repeats
6. In reverb mode, time = pre delay, and density = decay
7. This is not the same chip that the COTK and Blancet use.
8. Max delay time is 1 second I believe.
Let me know if you have any questions.
Jsharpphoto
Post by Jsharpphoto » Wed Oct 23, 2019 9:39 am
Henfield
Better Chemistry through Sound
Post by Henfield » Wed Oct 23, 2019 10:16 am
What is the depth? Will it fit into a Dotcom Box 11 (less than 3" depth)?
For Sale/Trade: 14U 84 hp Euro case . Willing to trade towards MU Modules, Moogerfooger pedals, Minifooger pedals, and other interesting effects boxes that work well with modular, try me!
Jsharpphoto
Post by Jsharpphoto » Wed Oct 23, 2019 11:07 am
Yes. It’s box 11 compatible
josaka
Post by josaka » Wed Oct 23, 2019 7:39 pm
suppose demos are too much to ask for..
been a year since the sys x system popped up.. not a one yet..
Jsharpphoto
Post by Jsharpphoto » Wed Oct 23, 2019 9:34 pm
josaka wrote:suppose demos are too much to ask for..
I will post video and audio demos as soon as mine arrives. I’ve only had my set of System X modules for about a month, and I’ve been traveling for work most of that time. I should have them up next week.
Jsharpphoto
Post by Jsharpphoto » Thu Oct 24, 2019 2:59 pm
I updated the original post to say that the reverb is also stereo. Unfortunately the delay is mono
diophantine
Post by diophantine » Thu Oct 24, 2019 8:34 pm
Anyone know what chip this uses?
Purveyor2
Post by Purveyor2 » Thu Oct 24, 2019 11:50 pm
Rick says it’s the V1000
Jsharpphoto
Post by Jsharpphoto » Sat Oct 26, 2019 1:18 pm
Correct. It’s the V1000
soon_come
Re: Stasis Leak by Frequency Central
Post by soon_come » Mon Jun 22, 2020 9:20 am
Has anyone noticed any audible issues with the sync input? Mine seems to receive the pulses just fine, but the delay length is audibly off by a noticeable amount.
daveholiday
Post by daveholiday » Wed Jun 24, 2020 10:15 am
I am getting ready to put one together in a few days......I'll check mine out for sync issues!
It is all shits and giggles,
until somebody giggles and shits.
soon_come
Post by soon_come » Wed Jun 24, 2020 10:18 am
Thank you, please let me know!
daveholiday
Post by daveholiday » Wed Jun 24, 2020 5:58 pm
So I went back and re-read your post...."delay length" or "delay timing"....if you are using the internal clocking such as 1/8 notes?
So if you are clocking the delay to repeat on 1/8 notes is the timing off? Or are the delayed notes being cut short?
Sorry for overthinking this!!
soon_come
Post by soon_come » Wed Jun 24, 2020 6:02 pm
It didn’t sync up at any time division. I was talking about delay length at max division length, but I think I may have figured out what happened. I was using half notes to clock it, and at the BPM I was operating at, it could’ve meant that I was just barely exceeding the max delay time. My theory (until I go back and test to confirm) is that it looked fine by eye but was obviously off by ear because it was actually not able to receive the second tap and kept resetting itself. I believe the max delay time is ~1s.
daveholiday
Post by daveholiday » Thu Jun 25, 2020 5:34 am
I will certainly check out mine (when I get it built) and post again. One thing I did with the waverunner after I built it was to see how slow it would sync. If I remember correctly, the slowest I could get it to sync was 2 measures @72BPM so plenty slow for what I am doing 85-120 BPM.
soon_come
Post by soon_come » Thu Jun 25, 2020 11:01 pm
OK, just tested it again, and my theory was wrong. I’m well within the max delay time between taps. I wonder if there’s a way to calibrate it, because it’s clearly off.
Rex Coil 7
Post by Rex Coil 7 » Fri Jun 26, 2020 4:02 am
I'm curious, what inspired the name of the module?
.. given the choice between conformity and self respect, I choose the latter.
.. dominion - noun: control or the exercise of control . power . possessed and controlled domain . sovereignty . having dominion over the world . supreme authority . absolute ownership . power . authority . jurisdiction . control . command ... power ....... power .......... power.
cubis
Post by cubis » Fri Jun 26, 2020 11:01 am
Very cool idea! I really like the fact that it's 1U
What do the L/R outputs do in delay mode? Are they just copies of the signal, or is one dry and one wet, or do we just use the standard L/Mono mentality?
daveholiday
Post by daveholiday » Sat Jun 27, 2020 7:24 am
Holy Shit Rex!! Way to open a can of worms....copied from the Merriam-Webster definition of stasis....
stasis noun
Save Word
To save this word, you'll need to log in.
Log In
sta·​sis | \ ˈstā-səs
, ˈsta- \
plural stases\ ˈstā-​ˌsēz
, ˈsta-​ \
Definition of stasis
(Entry 1 of 2)
1 : a slowing or stoppage of the normal flow of a bodily fluid or semifluid: such as
a : slowing of the current of circulating blood
b : reduced motility of the intestines with retention of feces
2a : a state of static balance or equilibrium : stagnation
b : a state or period of stability during which little or no evolutionary change in a lineage occurs
-stasis noun combining form
plural -stases
Definition of -stasis (Entry 2 of 2)
1 : stoppage : slowing hemostasis bacteriostasis
2 : stable state homeostasis
So if we go with 1b....Looks like you will need a change of boxers!
m0n0mania
Post by m0n0mania » Sat Jun 27, 2020 8:12 am
daveholiday
Post by daveholiday » Sat Jun 27, 2020 3:43 pm
Thank God there is a better explanation than.....
b : reduced motility of the intestines with retention of feces ....... +Leak!!! :yay:
Post by MindMachine » Sat Jun 27, 2020 11:01 pm
So like those Lays Potato chips Wow olestra - anal leakage.
FS: Pedals and Euro modules, Delta Labs, dotcom Q128 for 37.00
viewtopic.php?f=74&t=233636&p=3287718&h ... e#p3287718
Rex Coil 7
Post by Rex Coil 7 » Sat Jun 27, 2020 11:28 pm
... I need TP for my bunghole ....
I AM CORNHOLIO!!!!
daveholiday
Post by daveholiday » Fri Jul 17, 2020 5:10 pm
I haven't had the time to get mine built yet to test the sync issues. Are you still having problems, or did you get the issues sorted? I will try to build mine this weekend.
Return to “5U Format Modules”
