MIDI Merger Project
Sandrine
MIDI Merger Project
Post by Sandrine » Thu Oct 24, 2019 3:16 pm
I have designed a simple 3 way MIDI merger / splitter that can re-direct MIDI by Port and Channels.
There's also Clock routing, transport message, PC, CC port routing which is useful.
(HD best full-screen viewing)
It seems to work well thus far and will fulfill all my own needs.
It uses and Atmega2560( for the ports of course!) so could be used with the 2560 Arduino board as a shield. I used a raw TQFP100 breakout
It handles "running status" no problem and just about anything (except Active Sensing it ignores & SysEx it ignores).
Low latency <1mS simultaneously on all 3 outputs.
Nice OLED display with big chars and scrolling lists
I am posting the code (all my own) and other assorted info (user guide, parts, 3D printer info etc. but no schematics yet) so if anyone wants to make one, it'll be a piece of cake
Program:
http://www.freshnelly.com/midimerge/MIDImerge.zip
3d Print files (obj & stl):
http://www.freshnelly.com/midimerge/3D-MIDImergeBox.zip
Info & manual (doc):
http://www.freshnelly.com/midimerge/SDS ... ger3x3.zip
Sandrine
Post by Sandrine » Fri Oct 25, 2019 9:53 am
In answer to some PM's I don't see why this couldn't be a module!
8HP should be enough to fit the 6 jacks (panel mount) if placed strategically ...
Dave Kendall
Set The Controls . . .
Post by Dave Kendall » Fri Oct 25, 2019 11:19 am
Nice work Sandrine !
Want to Buy: KURZWEIL KSP8
"Everything in moderation, including moderation"
grenert
Post by grenert » Sat Oct 26, 2019 12:07 am
Very cool project, thank you for sharing it! I've never used a 3D printing service before. Do you have any recommended vendors?
Sandrine
Post by Sandrine » Sat Oct 26, 2019 8:59 am
Dave Kendall wrote:Nice work Sandrine !
Thanks Dave!
grenert wrote:Very cool project, thank you for sharing it! I've never used a 3D printing service before. Do you have any recommended vendors?
Naw, I do my own printing, but I have seen some in passing and they do a much nicer job :hail: Shapeways is pretty good at it from what I've seen
I use Maya-->obj-->Blender (free)-->Cura (free) to get to gcode for the printer. Printers are so super cheap now too
Sandrine
Post by Sandrine » Fri Nov 01, 2019 9:49 am
I have been thinking about what format a module of this would be for the best use
- 6 jacks 3.5mm TRS with toggle switches for polarity for 6 channels I/O
- 2 TS jacks for non-TRS MIDI
- USB slave for DAW & FW updates
- 2 host ports for USB MIDI
- Display & Encoder
I don't know how practical this would be with all the TRS jacks & wires snaking off to other than rack devices (because not strong like 5pin MIDI) but it would get rid of all those TRS/5pin adapters :yay:
Paranormal Patroler
Post by Paranormal Patroler » Fri Nov 01, 2019 10:32 am
There are TRS-to-DIN adapters that don't include cables. Check the orange one here:
You just plug a small TRS cable and you're done. You can even switch between Korg/Arturia mapping. a TRS only MIDI matrix would be awesome!
Sandrine
Post by Sandrine » Wed Nov 06, 2019 10:20 am
That's pretty cool! I like the no cable
With the weak 3.5mm midi going off-rack I guess one could 3D print up some "thimbles" that go under the nut, might work.
I have busted off my fair share (usually tripping over cables when I'm excited haha) so tend to flip them over the back which is also a PITA
