Doepfer attenuators with my Easel?
mousegarden
Post by mousegarden » Fri Oct 25, 2019 5:35 am
I'm thinking about putting together a 32hp case with some Doepfer utility modules, primarily passive attenuators. I'm assuming these will be safe to use straight, with my Easel, all I want to do is attenuate the voltage from the Aux Card oscillator, as the sliders on the CV inputs of my Easel don't offer enough resolution, they are way too coarse for this.
darmklacht@gmail.com
Post by darmklacht@gmail.com » Fri Oct 25, 2019 7:21 am
Mr. Mouse
Couldnt you just this with banana plugs soldered to each end?
Post by MindMachine » Sat Oct 26, 2019 9:09 pm
FS: Pedals and Euro modules, Delta Labs, dotcom Q128 for 37.00
viewtopic.php?f=74&t=233636&p=3287718&h ... e#p3287718
beem
Post by beem » Tue Nov 05, 2019 2:19 am
It shouldn't be a problem at all to mix formats with modules like that. Either use some format jumbler module or just special made cables. I do it all the time with my Serge stuff. As long as the machines share a common zero signal somewhere it works great.
For attenuation only you might find some cable with an attenuator on it that's usable too.
