1v/oct question
Leisure Cove
1v/oct question
Post by Leisure Cove » Sun Nov 23, 2008 4:12 pm
I tried controlling the frequency of my ELF LFO with the CV out of a Moog Rogue... this happened:
http://vimeo.com/2325136
What do you all think-- is the ELF LFO not tracking properly, or is the voltage coming out of the Moog no longer 1v/oct? And in latter case, how could I check? What would I use to measure control voltage?
wetterberg
Post by wetterberg » Sun Nov 23, 2008 4:28 pm
a multimeter - you should generally own one if you have a modular synth.
1 volt per octave - an interval quite easily measured, too :)
Leisure Cove
Post by Leisure Cove » Sun Nov 23, 2008 4:39 pm
Indeed-- I'll pick one up. Thanks!
wetterberg
Post by wetterberg » Sun Nov 23, 2008 4:41 pm
no problem. I'll be looking forward to that, by the way, since I have a sneaking feeling it's the ELF not tracking. And I'm on the fence about them at the moment.
MrDys
Post by MrDys » Sun Nov 23, 2008 11:02 pm
It's an LFO, not an oscillator. Don't expect oscillator tracking out of it.
chinard
Post by chinard » Mon Nov 24, 2008 2:01 am
doepfer makes a decent quantizer module (A-156)
its what i use in my rig for this task to get an lfo to pitch track such as you are trying here.
wetterberg
Post by wetterberg » Mon Nov 24, 2008 2:45 am
MrDys wrote:It's an LFO, not an oscillator. Don't expect oscillator tracking out of it.
Plan B wrote:The Model 37 ELF LFO has an identity problem. While specifically designed as an LFO, it's massive frequency range 1 cycle per 30 seconds to over 20Hkz makes it the perfect candidate for utility audio VCO applications. Incorporating a heavily-modified version of the TAU triangle core architecture, the M37 is capable of 1v/oct tracking across it's entire operating range when the external VC Attenuator is set to the full clockwise position.
There's nothing strange about wanting the ELF to track properly - it's advertised as such.
astroschnautzer
Post by astroschnautzer » Mon Nov 24, 2008 3:06 am
At some forum there was a thread about many people complaining about the elf lfo not tracking v/oct correctly, I guess it doesn`t then. I don`t think they should be advertised as such, there are other plan b products also that are advertised to do things they don`t do.
flts
Post by flts » Mon Nov 24, 2008 3:08 am
ELF LFO is a bitch to get around the V/oct scaling area - at least mine needs VC attenuator set to somewhat less than fully clockwise. And even then it doesn't track too well - somewhat close but that Plan B page majorly overstates how well. And I don't mean like "hey, it's a few cents off", but that it's a major PITA to try to do anything melodic with it. The basic osc timbre is really nice though.
I don't know if I have one that was badly calibrated out of the box or what, but I remember Rewire echoed that it's not a very good V/oct osc so at least I'm not alone. It IS awesome considering it's a LFO and not Cwejman though :lol:
wetterberg
Post by wetterberg » Mon Nov 24, 2008 3:34 am
thanks for the info, lads - it's all I needed to know! Time for "Plan D" - buying up Doepfer 110s and modding them :twisted:
110s and Doepfer vcLFOs is my new plan of attack :)
astroschnautzer
Post by astroschnautzer » Tue Nov 25, 2008 2:38 am
wetterberg wrote:thanks for the info, lads - it's all I needed to know! Time for "Plan D" - buying up Doepfer 110s and modding them :twisted:
...interesting...
felix
Loves the manuals!
Post by felix » Tue Nov 25, 2008 3:49 am
flts wrote:ELF LFO is a bitch to get around the V/oct scaling area - at least mine needs VC attenuator set to somewhat less than fully clockwise. And even then it doesn't track too well - somewhat close but that Plan B page majorly overstates how well. And I don't mean like "hey, it's a few cents off", but that it's a major PITA to try to do anything melodic with it. The basic osc timbre is really nice though.
That's quite a disappointment. I was hoping to get a few mini-M15s out of the ELF LFOs. I'd rather get a 2nd Vulcan now.
Leisure Cove
Post by Leisure Cove » Tue Nov 25, 2008 10:41 am
felix wrote: That's quite a disappointment. I was hoping to get a few mini-M15s out of the ELF LFOs.
My feeling exactly. Especially for a small, budget-challenged system (read: mine), the ELF LFO seemed to me to be an ideal way to fit a bunch of oscillators into the equation. Plus, it doesn't sound half bad in VCO mode!
Other ELF LFO owners: does your unit track? I'll fiddle with the VC Freq knob on mine tonight and see if I can't stumble across a position that scales v/oct. Maybe it's secretly a bi-polar attenuator... :confused:
flts
Post by flts » Tue Nov 25, 2008 11:41 am
Leisure Cove wrote:Other ELF LFO owners: does your unit track? I'll fiddle with the VC Freq knob on mine tonight and see if I can't stumble across a position that scales v/oct. Maybe it's secretly a bi-polar attenuator... :confused:
There IS a position where it will track close to V/oct, it's just a bitch to get right since there's just a little single turn knob for the whole VC attenuation... on my ELF LFO, it's somewhere between the middle and full VC. And even then it's like "well it gets close to V/oct but starts deviating quite quickly".
