Passive Bus Boards; 9u84hp: 2x MDLRCase, Nano or other?
Tristana
Post by Tristana » Fri Nov 01, 2019 12:05 pm
I am building a 9U, 84HP case with two 3 amp supplies & a filter board designed by my housemate.
I'm looking to grab passive bus boards, but haven't found many reviews of the ones featuring 20 headers. The one review of the Nano board I found complained that small traces lead to greater impedance.
I did have Doepfer's boards in my LC6, but only grabbing 2 might not fully support the full 252hp of modules, hence looking into other options.
Any experience with the two I mentioned, or other recommendations?
ππ„πŽ-𝐑𝐀𝐕𝐄 π’πŽπ”ππƒπ’ππ€π‚π„: http://madeONLINE.me/
Have my freebie granular plug-in: viewtopic.php?t=192886
Luap
Post by Luap » Fri Nov 01, 2019 12:25 pm
Bastl Juice board kits? I run a couple of those and i've been pleased with them.
(They also have +5v regs)
Tristana
Post by Tristana » Fri Nov 01, 2019 12:28 pm
Luap wrote:Bastl Juice board kits? I run a couple of those and i've been pleased with them.
The kit sells for the same as some pre-made bus boards and Modular Addict seems out of them- other than a desire to solder is there a particular reason to grab 'em?
abelovesfun
Post by abelovesfun » Fri Nov 01, 2019 1:33 pm
Super Easy, Awesome DIY kits @ http://www.aisynthesis.com
modular ambient and composery music @ http://www.forcedamage.com/
https://www.facebook.com/forcedamagemusic
Tristana
Post by Tristana » Fri Nov 01, 2019 3:17 pm
abelovesfun wrote:I also have them from $15 - 75
https://aisynthesis.com/product/eurorac ... ution-kit/
The filter board my housemate built already has optional 5v and power filtration; could your board be built with only the socket headers & LEDs, potentially shorting some things if needed?
joem
Post by joem » Fri Nov 01, 2019 4:22 pm
I'm pretty sure it could be, easily. Though there's no 5V input blade, so you'd need to jury rig something to connect your filter board's 5V to. Shouldn't be too hard, but it won't look as pretty as something that isn't designed to have a 5V regulator on it.
abelovesfun
Post by abelovesfun » Sat Nov 02, 2019 4:30 pm
Yes. This board can use a variety of phoenix connectors, or just wire pads to connect to other boards.
Return to β€œMusic Tech DIY”
