Make Noise Rene + Tempi for live performance
Live patching, designs, and techniques that push the performance envelope.
paranormind
Post by paranormind » Sat Nov 02, 2019 9:11 am
Howdy!
I historically used my Tempi and Rene (mk2) separately for live performances. But now, I'd like to try to leverage the CV bus. I can conveniently switch bank/state from the Rene which will change the Tempi state accordingly.
The problem is the following. Let say I have properly configured State 1, 2, 3 and 4 on my Rene. If I load say State 2, and decide to mute/unmute the channel 1 from the Tempi, then I'm unable to properly load another state. It will have no effect at all. It's like if the Tempi had overridden everything. I can power cycle my case and everything will go back to normal, but you guess it, I'd like to avoid that :-)
paranormind
Post by paranormind » Sat Nov 02, 2019 9:24 am
(the workaround I found is to record all the different combinations as state and then switch between states, but that's moderately convenient for a live set)
Return to “Play Out! Performance Modulars”
