problem with 292e (not find by preset manager)
Crumar
Post by Crumar » Sat Nov 02, 2019 9:31 am
Hello,
just got a 200e and everything works fine except for the 292e.
At the boot the 206e finds 5 CPUs (250e, 261e, 281e has 2 and 206e) but when I hold down the remote enable on the 292e it won't display anything.
Other than that everything works.
Also once the remote enable led is off, I can turn it back on by moving one of the four knob, an disabled by pressing REM. but i can't turn it bak on by press REM
Any idea? thank you
dougcl
Number 6
Re: problem with 292e (not find by preset manager)
Post by dougcl » Sat Nov 02, 2019 10:03 am
It's probably on the old v2 firmware. Update to latest firmware should fix.
Crumar
Post by Crumar » Sat Mar 21, 2020 7:32 am
hi i have try to update the module but i think todo something wrong becaìuse now the module does'nt work and the led are all illuminated, can anyone help me? i don't understand very much the procedure to update :hail:
