1/4" TRS female jack through 3/8" plywood?
Tristana
Post by Tristana » Sat Nov 02, 2019 9:06 pm
Are there any 1/4" TRS jacks long enough to fit through 3/8" plywood available (bonus points if they vertically mount to a PCB)?
I am in the process of designing a case, and am looking to build a patch bay into the side of it for 1/4" TRS to 1/8" TS conversion. The goal is to run 1/4" TRS cables out of my DC-coupled interface into 1/4" TRS jacks on the side of the case, which will in turn be wired to a euro panel with an equivalent amount of 1/8" TS jacks. The reason for TRS at the receiving end is to leave the ring open/floating without the use of a specialized cable.
I'm hoping to find jacks that can fit through the plywood directly, rather than cutting at a hole for a panel on the side.
ππ„πŽ-𝐑𝐀𝐕𝐄 π’πŽπ”ππƒπ’ππ€π‚π„: http://madeONLINE.me/
Have my freebie granular plug-in: viewtopic.php?t=192886
Revok
Post by Revok » Sat Nov 02, 2019 9:15 pm
The Switchcraft 152B might work if it isn't too long.
Tristana
Post by Tristana » Sat Nov 02, 2019 10:42 pm
Revok wrote:The Switchcraft 152B might work if it isn't too long.
Thanks for the suggestion! cheapest I can find is at B&H for $6.31 a pop (reasonable for this?), and I'm terrible at reading data sheets- I think those are a bit long (2.3 inches total)?
Was also perhaps hoping for something insulated & PCB mountable.
Revok
Post by Revok » Sat Nov 02, 2019 11:01 pm
They're pretty pricey. $6.31 is probably going to be tough to beat. They are 2.319" but you might be able to cut the shield lug/cable mount to get it down a little bit.
Astrolabe23
Post by Astrolabe23 » Sun Nov 03, 2019 12:05 am
I've had good luck making recessed plugs on thicker wood panels using forstner bits to make a larger circle cut out and reducing the final "panel" thickness where the plug actually mounts. It helps protect the jacks too by having them countersunk. The nice thing about the forstner bits is that they make a perfectly smooth cut and leave a flat surface at the bottom of the hole. They work best with a drill press that you can set the stop depth on. This allows you to get perfectly identical cuts for multiple holes. You can do it with a handheld drill but it can take a bit of practice to get the depth right without going all the way through. The other drawback is the bits are not super cheap. $30 - $40 US for a decent set, but if you do much wood working they come in handy all the time. Below is a photo of a test jack I made on a scrap of wood to find the right depth setting. You can see a more shallow unfinished test hole at the back of the block.
Here is what the bits look like:
kamielsd
Post by kamielsd » Mon Nov 04, 2019 8:40 am
a bit oftopic.. but this works quite well for mounting minijacks in aluminium panels thicker then 2mm using these things.. Image
keninverse
Post by keninverse » Mon Nov 04, 2019 10:20 am
+1 for forstner bit or if you have a router then a spiral bit with a template.
ersatzplanet
Synthwerks Design
Post by ersatzplanet » Mon Nov 04, 2019 12:53 pm
Here are three from switchcraft that will do it. -
-James
Tristana
Post by Tristana » Mon Nov 04, 2019 4:44 pm
ersatzplanet wrote:Here are three from switchcraft that will do it. -
Thanks! I do like the finish of the 155, it'd match the rails I'm using.
I'm thinking the most cost effective option is gonna end up being routing out a cavity like the others mentioned, I can get pcb mount jacks for $0.50 a pop.
Tristana
Post by Tristana » Mon Nov 04, 2019 4:47 pm
For a jack like this, how thin should I route the plywood to to still accommodate the jack without making it too structurally weak?
I'm terrible at reading spec sheets, I think the threaded part is 8mm long?
https://www.taydaelectronics.com/datasheets/1121-1.jpg
JimY
Post by JimY » Tue Nov 05, 2019 4:51 am
You can use a hole saw/tank cutter and make a big hole. Then glue & pin a piece of plywood - 3mm 1/8" across the back or screw/bolt a spare piece of metal panel. That's what I would do since it rules out having to worry about routing depth. I would still use the router to make a nice rounded corner to the hole.
Note that for speaker/cabinet builders, there are plastic moulded "dishes" with pre-made holes for jack or XLR connectors. These fit into a hole from the outside. Inexpensive, but they are quite large.
https://www.terralec.co.uk/speaker_gril ... 582_p.html
Boris_Yeltsin
Post by Boris_Yeltsin » Tue Nov 05, 2019 9:16 am
^^^ This is probably the easiest and most fool proof way to do it as long as you are fine with the jacks being recessed. I've done the same thing for mounting buttons to wooden boxes and it works great.
ersatzplanet
Synthwerks Design
Post by ersatzplanet » Tue Nov 05, 2019 4:22 pm
Boris_Yeltsin wrote:^^^ This is probably the easiest and most fool proof way to do it as long as you are fine with the jacks being recessed. I've done the same thing for mounting buttons to wooden boxes and it works great.
Also it allows you to easily change things in the future if you want to add another jack, or a different type of jack. You just make a new sub panel and do nothing with the hole in the wood. My old 4-voice and 2-voice Oberheims had panels behind large square holes and it was great for all the mods I made.
-James
UltraViolet
Post by UltraViolet » Tue Nov 05, 2019 6:17 pm
I agree with Boris as well. If you just need 1 or 2 jacks then the recessed holes would be a good solution. For a number of jacks the small panel would be easier and provide more flexibility.
electricanada
Post by electricanada » Tue Nov 05, 2019 9:35 pm
You guys are doing it the hard way. Just buy a guitar jack plate off ebay for 50 cents or whatever and use a regular socket.
Here you can get the plate and the jack both for a dollar including shipping:
https://www.ebay.com/itm/black-Square-S ... SwBOtY9GeU
Tristana
Post by Tristana » Tue Nov 05, 2019 11:26 pm
electricanada wrote:You guys are doing it the hard way. Just buy a guitar jack plate off ebay for 50 cents or whatever and use a regular socket.
Interesting! Those do seem convenient.
Not sure if I'd find it the most aesthetically awesome or aesthetically awful in a case stained carbon gray (like this: viewtopic.php?t=193907&highlight= ); I have already grabbed black rails... not sure if the included plate can be made to be flat against the case, though.
What I'm less keen on is the shipping from 'sex-plaza2014' having a potential arrival date of January 21st though it's not abnormal for parts from China.
I've decided I also want L+R outputs at the same location, so perhaps 2 rows of 5 of these on the side of the case matched to an 4hp euro plate of 2 rows of 5 1/8" TS jacks would be the way to go.
Edit: forgot of my original goal for the inputs to be TRS jacks whereas those'll be TS. I could grab just the plates and stick sockets in 'em? https://www.taydaelectronics.com/hardwa ... inals.html
Revok
Post by Revok » Wed Nov 06, 2019 12:37 am
Those guitar jack plates will have a slight curve. Look for speaker jack plates instead. There are small black circular ones that might look nice with your case and they will be flat.
Return to β€œMusic Tech DIY”
